Camlespaul6 Posted February 6, 2018 Share Posted February 6, 2018 I have a problem with my amp and pedal combination. I have a line 6 spider iv 150w and a brand new fbv mkii shortboard. The amp works perfectly when it's not plugged into the short-board and will do everything as expected. Once I plug in the short board I find the amp rebooting or shorting or something. It turns off for a second or two and then turns back on. I then tried plugging the short board into my old spider iv 15w and it worked without cutting the amp. I downloaded line 6 monkey and updated both the short board and the amp (and the amp didn't reboot while the shortbread was plugged into both it and the laptop). I tried swapping the cable between the fbv and the amp and that changed nothing. Not sure what to do now. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted February 6, 2018 Share Posted February 6, 2018 Double check the small connectors in the amp jack to make sure none are bent out of position. If all seems well, you'll need to start a Support Ticket here on Line6.com. Quote Link to comment Share on other sites More sharing options...
Camlespaul6 Posted February 6, 2018 Author Share Posted February 6, 2018 Hey thanks for the reply. They all look mint. I've made a ticket but line 6 hasn't responded yet. Need an answer urgently as I have to return the board before the end of the week... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 6, 2018 Share Posted February 6, 2018 They should be getting back to you soon. I've been in contact with them. Quote Link to comment Share on other sites More sharing options...
