Blondiedk Posted February 8, 2018 Share Posted February 8, 2018 Ext amp doesn't work probably after updating When switching ext amp with snapshots, the switch on the Helix (set in command center) switches status, but nothing's happening on the Amp. It worked perfectly in 2.30 but not in 2.50 1 Quote Link to comment Share on other sites More sharing options...
welshboyohelix Posted February 8, 2018 Share Posted February 8, 2018 Yep, I'd like to 2nd this - tried resetting the tip/rings designations from Command Center, no joy 1 Quote Link to comment Share on other sites More sharing options...
JC-Tonequest Posted February 11, 2018 Share Posted February 11, 2018 I'll 3rd this...Channel switching with my Friedman JJ100 no longer works. Well it actually works if you select the footswitches in command center to change the channels but you cannot save the state of the ext amp footswitches per snapshot. Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 11, 2018 Share Posted February 11, 2018 It’s a known bug that will dealt with in an upcoming patch. 3 Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted February 12, 2018 Share Posted February 12, 2018 Still works on my Marshall amps. Quote Link to comment Share on other sites More sharing options...
