Variax 300/600 workbench connectivity issue via HD500 (Vista)
Hi guys,
Digital gadgetry has a bad day?
Does anyone know of an issue regarding connectivity between Variax 300/600 and workbench using Pod HD500, and Windows Vista? I have no issues with connecting to Monkey, or HD Edit, via the same connection.
So here's the story...
I successfully reflashed the firmware using Monkey in my 300/600 vaxplant, as I was having a strange warbling issue all of a sudden on the open 6th E, and fretted F. So after reflashing, I go back into Workbench to reload all my user patches from a backup, and it won't connect. I used monkey to download Workbench again, used the Line 6 uninstaller to uninstall Workbench, then re-installed it. Still no banana. Doesn't even recognise 300/600 as being connected. Disconnect everything, reconnect, still no banana.
I connected to my MacBook Pro, and everything connected fine, reloaded patches fine.
So I had a workaround, but I still want to have connectivity, as my computer workspace is where I usually do it all.
  • 4 weeks later...
Are you getting any "JAVA" errors?
The Workbench installer tries to install an old version of JAVA that doesn't connect anymore... you need to install JAVA separately.
http://javadl.oracle.com/webapps/download/AutoDL?BundleId=230540_2f38c3b165be4555a1fa6e98c45e0808
I also notice you said you used Monkey to re-install Workbench.... which version of Monkey? I have found the latest version wants to install Workbench HD which doesn't work with the 300/600. I needed to manually download/install Workbench (not the HD version) and Java separately... then it all worked.
SOLVED:
Thanks for your response codamedia - no java errors, and monkey installed correct workbench...
I had the need to try it again last night, and with success - went through the process of selecting device, and found I had to select the Pod HD500 first, which I hadn't done on the previous (unsuccessful) effort. Although I felt it all somewhat confusing, I guess I'll have to put that one down to user error.... I don't recall having to do that ever before.
LOL - I made that same error on my desktop... and like you I ended up chalking it up to "user error". My laptop has always connected (I guess I made the right choice years ago) but when setting it up on my desktop it was a little frustrating.
It's not the most intuitive interface... but it does actually work.
