martinconte Posted March 21, 2018 Share Posted March 21, 2018 My blackstar stock channel switching pedal is not working while using hx effects. I cannot switch to channel two. It's as if channel two is bypassed. The pedal turns red as does the channel two light but channel two seems to be disabled. If I plug my guitar directly into my amp and disconnect the hx effects entirely channel two works again, but once I reconnect the hx effects the stock pedal can only be used to turn on and off reverb and channel switching is disabled. I'm currently using the 4 cable method. Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 21, 2018 Share Posted March 21, 2018 It sounds like you're probably bypassing your amp's preamp. In order for the 4 cable method to work with the HX Effects, you have to inserts an FX Loop block in its signal chain. It's different than the M13, in case that's what you were coming from. Quote Link to comment Share on other sites More sharing options...
martinconte Posted March 21, 2018 Author Share Posted March 21, 2018 Human error strikes again, thanks Quote Link to comment Share on other sites More sharing options...
