Foamdad Posted March 21, 2018 Share Posted March 21, 2018 I have my UX2 analog outs running into a Behringer Xenyx Control USB via balanced 1/4" cables, and out to Presonus powered desk monitors. I have noticed that the output is very low, and I have to crank the volume on the Behringer to hear anything. The output knob on the UX2 is cranked and the Behringer passes audio normally on the input connected to my compy's soundcard (connected to the Behringer via RCA cable). I have tried this on the two balanced ins on the Behringer to the same effect. Is this a function of the UX2 ASIO driver, or is the native output coming from the UX2 just very low? Thanks! Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted March 21, 2018 Share Posted March 21, 2018 It sounds like a long winded way of doing things. What is the behringer control usb doing other than outputting to your monitors? The ux2 replaces your on-board Sound card, so I'm not sure why you use that as well. have you tried hooking your your monitors directly to the ux2 and setting your ux2 as your playback device in your pcs settings? Quote Link to comment Share on other sites More sharing options...
Foamdad Posted March 22, 2018 Author Share Posted March 22, 2018 4 hours ago, Gaz_Ham said: It sounds like a long winded way of doing things. What is the behringer control usb doing other than outputting to your monitors? The ux2 replaces your on-board Sound card, so I'm not sure why you use that as well. have you tried hooking your your monitors directly to the ux2 and setting your ux2 as your playback device in your pcs settings? I have multiple sources going to my desk monitors. The Behringer just gives me control over switching between what goes to the monitors and singular volume control. Anyway, the playback settings are the first thing I checked, and everything looks good there. I also ran the analog outs from the UX2 directly into my desk monitors and the output is just as low (even with the output knob cranked). There is no problem passing signal, its just a very low output volume coming from the UX2 analog outs. Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted March 22, 2018 Share Posted March 22, 2018 Ok then. If you plug some speakers straight in to the ux2 and the volume is fine, it's not an issue with the output of the ux2 i would say. It would be something further down the chain. It would be best to check that first, to see if it is the unit or not. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted March 22, 2018 Share Posted March 22, 2018 Are you using Windows 10 (or 8)? If so, check the computer's Win audio settings (not the soundcard's). It may be set very low (yet default is usually 100%). Quote Link to comment Share on other sites More sharing options...
Triryche Posted March 22, 2018 Share Posted March 22, 2018 What's low, guitar tones, vocals, DAW playback, computer sounds, everything? Quote Link to comment Share on other sites More sharing options...
