martinconte Posted March 21, 2018 Share Posted March 21, 2018 When I switch to channel two on my amp I can still hear my clean guitar over it. I'm using the 4 cable method. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted March 21, 2018 Share Posted March 21, 2018 I'm assuming one of your paths has nothing on it and you don't want to hear it. If that's true then my guess is it's input is assigned to your guitar as well and that's what you're hearing. You can either assign it to nothing or go to the output and assign that to nothing. Quote Link to comment Share on other sites More sharing options...
martinconte Posted March 22, 2018 Author Share Posted March 22, 2018 Sorry, should have specified I'm using the hx effects pedal, not the full helix, so there's only one path Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted March 22, 2018 Share Posted March 22, 2018 Can you post a picture of your preset? sounds like you have a branch around your preamp that you are feeding clean signal to so you have your amps preamp signal and a clean signal going to your effect return on your amp. Quote Link to comment Share on other sites More sharing options...
TRENDKILLCFH333 Posted March 22, 2018 Share Posted March 22, 2018 I experienced this last night - while in 4CM when I turned on the TS 808 model OD (yes, it is placed before the FX Loop block). I'm using the HX Effects unit as well. It's not a major issue as I can just use my TS Mini in front of the HX Effects or through Loop 2, but it was disappointing. I did not hear any clean guitar tones when switching amp channels to crunch or OD. Quote Link to comment Share on other sites More sharing options...
