FunkyMan66 Posted April 11, 2018 Share Posted April 11, 2018 When trying to record audio through my POD HD500 via USB to my computer I am only getting loud crackling noises - so loud it hurts my ears. I am using my headphones plugged into the back of the pod for output. What can I do? I'm pretty sure the driver is installed properly Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 12, 2018 Share Posted April 12, 2018 Check your recording program and make sure that the audio setup is configured to use the HD500X and its ASIO driver. Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 12, 2018 Share Posted April 12, 2018 14 hours ago, FunkyMan66 said: I'm pretty sure the driver is installed properly Have you run the Line6 Monkey to verify? Quote Link to comment Share on other sites More sharing options...
FunkyMan66 Posted April 12, 2018 Author Share Posted April 12, 2018 I was able to change the settings in Ableton Live to ASIO instead of MME and I am no longer getting the clicking noises but, but apparently now I am getting a moderately low db signal as input to the PC. Any way to fix this? Quote Link to comment Share on other sites More sharing options...
FunkyMan66 Posted April 12, 2018 Author Share Posted April 12, 2018 Anything that is sent to PC is low strength while anything sent from PC to monitors is too high Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 13, 2018 Share Posted April 13, 2018 Here's a snip from the manual that may be relevant: Note that the type of audio signal fed to the Record Sends is controlled by the Output Mode setting found in the POD HD500 Setup:Outputs screen. For most USB recording situations, you’ll likely want to set this to “Studio/Direct.” Please see “Page 4, Setup: Output Options” on page 2•8 for more info. Quote Link to comment Share on other sites More sharing options...
FunkyMan66 Posted April 14, 2018 Author Share Posted April 14, 2018 I do have it set to studio/direct Quote Link to comment Share on other sites More sharing options...
