jaydeeboxster Posted April 16, 2018 Share Posted April 16, 2018 I had the embarrassing situation of inadvertently triggering the loop feature during a gig. Is it possible to disable this feature through configuration as having the function button next to the down bank button is too easy to hit by accident. Quote Link to comment Share on other sites More sharing options...
ADBrown Posted April 16, 2018 Share Posted April 16, 2018 Which amp are you using FBV3 with? I don't believe it is possible to disable the loop feature with any FBV3 compatible amp. Quote Link to comment Share on other sites More sharing options...
cloph Posted April 16, 2018 Share Posted April 16, 2018 As the FBV3 just is a controller with no mind of its own: easiest would be a "hardware fix", in other word put a cap over the button so you cannot press it anymore. Not sure whether the dunlop rubber knob covers would fit/be sturdy enough, but you can also just drill a hole in some piece of wood and put it over the knob and glue it down (use the nifty superglue on painter's tape trick to be able to remove it again without leaving residue) Quote Link to comment Share on other sites More sharing options...
jaydeeboxster Posted April 16, 2018 Author Share Posted April 16, 2018 1 hour ago, ADBrown said: Which amp are you using FBV3 with? I don't believe it is possible to disable the loop feature with any FBV3 compatible amp. Spider V 120 Quote Link to comment Share on other sites More sharing options...
ADBrown Posted April 16, 2018 Share Posted April 16, 2018 52 minutes ago, jaydeeboxster said: Spider V 120 There isn't anyway to disable the loop function on FBV3 between these two products. Quote Link to comment Share on other sites More sharing options...
jaydeeboxster Posted May 21, 2018 Author Share Posted May 21, 2018 Wine bottle screw cap and gaffer tape it is then Quote Link to comment Share on other sites More sharing options...
Bear706 Posted August 27, 2018 Share Posted August 27, 2018 so with a POD HD Pro X, can I reassign FS1 to do something that I will actually use? For me, a foot switch that operates a Looper, is a waste... I'll never use it. what exactly does the Function button do? Quote Link to comment Share on other sites More sharing options...
