Volume pedal settings please
jesuscares
Hi guys,
Just graduated from HD 500X to Helix LT.Usingf Helix Edit I downloaded & programmed a ton patches from Custom tone & got them onto Helix.I found the Volume pedal (Exp pedal) on the Helix does not work like the HD 500.The volume transition from heal to Toe position on each of the  patches seems to vary from patch to patch.On some the transition is smooth & on some the volume suddenly bumps up while using the pedal.Is there a setting to I need to make to avoid this?
Also on some patches the volume pedal does not work at all.How do I turn the volume pedal function on, on these patches?
Thanks
The HD500 volume pedal is fixed to linear taper which is actually very unnatural. Most people prefer an audio taper for a volume pedal. The Helix has the option to set the taper to linear or audio and that is likely what you are experiencing from patch to patch. Find the setting used in the patches you like and go with that for all the others.
The same way you would have on the HD500.... insert a volume pedal block and assign the exp pedal to it.
