munkeyboy7777 Posted May 17, 2018 Share Posted May 17, 2018 Received this m13 as is from someone. Before I buy a new power supply for no reason or open up and replace lcd screens, I wanted to get an opinion on what could be possible issues here. The m13 works and all the screens power up with colors. However, starting from left to right, each screen text display gets worse until the far right screen barely has anything displayed. The first screen is at least readable, but the others are not. The progressive degradation from left to right leads me to think it could be a power issues, but IDK. (FYI, I just flashed the latest firmware update with no change.) Pics below, Thanks!!! Quote Link to comment Share on other sites More sharing options...
kraftybob Posted May 22, 2018 Share Posted May 22, 2018 I've not seen this before. I have a few pixels now then disappear in a window but nothing like this. I'm no electrical engineer, but I would think if it was a power issue the screen would display but be dimmer, and all of them - not progressive as you go from one to the next. Quote Link to comment Share on other sites More sharing options...
munkeyboy7777 Posted May 22, 2018 Author Share Posted May 22, 2018 Yeah, i'm gonna open it up soon. Thinking it could just be loose contacts (tho it looks like the lcd is connected via pins). Maybe the PO dropped it and jiggles the connections loose. Quote Link to comment Share on other sites More sharing options...
munkeyboy7777 Posted May 22, 2018 Author Share Posted May 22, 2018 So, I think it is liquid damage. Upon opening it up, there is something on the jacks and looks to be something in the lcd screens too. But i could be deoxit or some sort of light oil. Hard to tell tho as it's just a light sheen. But probing the worst lcd bezel while plugged in and on, makes it worse. I think the ribbon cable inside the lcd unit is lifting off. Is there a cheaper place to get 4 LCD screens than the $25 a piece I've found (fullcompass)? Quote Link to comment Share on other sites More sharing options...
kraftybob Posted May 23, 2018 Share Posted May 23, 2018 Bummer to hear. Unfortunately I don't know where to source these. Aside from the LCD's how does the rest of the device work? If there's liquid damage I'd be concerned about something else being bad too. Quote Link to comment Share on other sites More sharing options...
munkeyboy7777 Posted May 24, 2018 Author Share Posted May 24, 2018 The device works great, aside from not seeing what is going on. I started to remove the lcds, but man it is difficult to desolder all those and the tricks to desolder header pins like that doesn't work because it's soldered in two places (both boards). I have a chip quik low temperature solder kit coming in, so hopefully that will help. But after that I don't have much hope I can fix the lcds. So I'll prob end up paying $100 or so to fix this thing. I'm sure it's worth it tho, as I love my m5. Quote Link to comment Share on other sites More sharing options...
jethroviloria1 Posted June 18, 2018 Share Posted June 18, 2018 Hey any luck fixing the lcd? Quote Link to comment Share on other sites More sharing options...
mylesloud Posted February 3, 2020 Share Posted February 3, 2020 It is definatley worth getting it fixed. Sound like you got it for free. Great unit!!! Quote Link to comment Share on other sites More sharing options...
