Starcruiser Posted May 22, 2018 Share Posted May 22, 2018 HI, I'm fairly new to the Helix and are examining every possibility to use it on stage... Is it possible to trigger a MIDI event when changing Snapshots? To my understanding the Command Center settings are per Preset? Thanks for any clarifications /Magnus Quote Link to comment Share on other sites More sharing options...
soundog Posted May 22, 2018 Share Posted May 22, 2018 the footswitch action itself can send a midi event...which of course is also selecting a snapshot. Quote Link to comment Share on other sites More sharing options...
Starcruiser Posted May 22, 2018 Author Share Posted May 22, 2018 Are you sure? If I set up footswitch 8 to send a MIDI note it works fine as long as I am in "Stomp mode". If I switch to "Snapshot mode" however, nothing is transmitted. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 22, 2018 Share Posted May 22, 2018 I haven't needed to use midi with snapshots, but I think I read somewhere that there's a problem with it that's being fixed in the next update....? Quote Link to comment Share on other sites More sharing options...
soundog Posted May 23, 2018 Share Posted May 23, 2018 ...not certain and haven't tested it ... so maybe I made a bad assumption ;-( Quote Link to comment Share on other sites More sharing options...
rbum Posted May 23, 2018 Share Posted May 23, 2018 Yes it is possible to send different midi messages with every snapshot, but it' s a bit tricky though. Like everything in snapshots it's also in command center with midi: every change in one snapshot will be repeated in the following ones unless you change it again. For midi that means, that a cc message with value 0- 66 will be send (again !) with every following snapshot until you change that value to 67 -127. If you need more multiple cc messages in differnet channels, you have to set the values right in every snapshot you use, which can be complicated. Also sometimes there seems to be a bug and the values change from - for example- 127 to 125 while saving, which can make a difference depending on what you want to achieve. If you set it right, you can - for example - start recording a sequence in an external looper in one snapshot, stop the recording in the next snapshot and start to play the loop in another one, which is pretty cool because the Helix looper is of no use for live music as long as you use snaphots in my opinion. In the past some of the these programmed midi messages got lost / confused by some firmware updates, where there might have been major changes in the midi functions. Didn't manage to "repair" all my settings afterwards because of the time needed to fix it. Quote Link to comment Share on other sites More sharing options...
Starcruiser Posted May 23, 2018 Author Share Posted May 23, 2018 Thanks, Let me see if I understand this: In Snapshot 1 i go into Command Center and say that "instant 1" is Change Prog 1 In Snapshot 3 i change that so that "Instant 1" is Change Prog 3. Now when using this: Snapshot 1-> MIDI ChangeProg 1 Snapshot 2-> MIDI ChangeProg 1 Snapshot 3-> MIDI ChangeProg 3 Correct? My only concern then is that I wanted to have the option of sending a Note and thats not available as "instant" messages. Next update? ;-) Quote Link to comment Share on other sites More sharing options...
rbum Posted May 24, 2018 Share Posted May 24, 2018 18 hours ago, Starcruiser said: Thanks, Let me see if I understand this: In Snapshot 1 i go into Command Center and say that "instant 1" is Change Prog 1 In Snapshot 3 i change that so that "Instant 1" is Change Prog 3. Now when using this: Snapshot 1-> MIDI ChangeProg 1 Snapshot 2-> MIDI ChangeProg 1 Snapshot 3-> MIDI ChangeProg 3 Correct? My only concern then is that I wanted to have the option of sending a Note and thats not available as "instant" messages. Next update? ;-) Well , there are different midi messages: I used only cc messages, not pc (program change) messages. It depends on what your receiving machine needs to do what you want ... As far as I know the pc messages are send everytime you change a present (unless you deactivate this option in globals), but can also be send with snapshots. For notes I guess you'll need cc messages with value... Quote Link to comment Share on other sites More sharing options...
