Phil110567 Posted June 4, 2018 Share Posted June 4, 2018 Hi there ! I know about IR as a mean to create cabinet simulation. I can't see how it applies to the HX effect. Is acoustic IR way to simulate typical acoustic guitar response ? For example, is an acoustic IR intended to simulate an acoustic guitar response from an electric ? Do you use acoustic IR ? what kind of usage ? Quote Link to comment Share on other sites More sharing options...
ADBrown Posted June 4, 2018 Share Posted June 4, 2018 I use acoustic IR's to change the sound/timbre of an acoustic guitar. People have also been able to get electric guitars to sound acoustic using acoustic body IR's, I find results vary in this category and going electric to acoustic sounds takes a bit more dialing in. Quote Link to comment Share on other sites More sharing options...
maikito26 Posted June 4, 2018 Share Posted June 4, 2018 I've found that Acoustic IR's while using my Acoustic is truly where this shines for me. It helps provide a more mic'd sound rather than direct in even before EQ. My chain goes Compressor > IR > Para EQ. I've also found that Cab IR's are useful when I don't want to carry my 4x12 cab around. I can still use my Marshall JVM410H amp for the pre-amp, and with the HX in 4CM configuration. And the Cab IR's really do sound not that bad. In a third method, I split the signal and use both my 4x12 and an IR to the PA. I could use the Emulated out on the JVM410H for this, but I'm already connected from my board to the PA for my acoustic. Therefore I don't need to take up to channels on the mixer. 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted June 5, 2018 Share Posted June 5, 2018 14 hours ago, Phil110567 said: I know about IR as a mean to create cabinet simulation. I can't see how it applies to the HX effect. There are many uses for a cabinet IR in the HX. Just because the HX is marketed as a "pedal board in front of an amp" does not mean it is limited to just that. The routing options make it very versatile. Just a couple IR cabinet uses.... 4cm setup.... split path after return from the amp. Use a cabinet IR in one path to send directly to a recording device, console, etc... etc... while sending the other path back to your amp for stage use. Any "amp in the box" pedal can be placed in an effects loop... (eg: Mesa V-Twin, Catalinbread RAH or DLS, etc... etc...) then insert an IR and send the signal directly to recording or console. As for other IR uses.... I use them on my acoustic, dobro, classical, mandolin, banjo, etc... etc... Finding a nice IR (or creating your own) can add a lot of depth to some acoustic instruments. They are not intended to make an electric guitar sound like another instrument... but you can certainly experiment to varying degrees of success. Quote Link to comment Share on other sites More sharing options...
