AntonisPat Posted October 23, 2013 Share Posted October 23, 2013 Hi all This might sound as a noob question (but then again I am one :) ).. I'm trying to understand how the SV series (MKII 112 in my case) is set up.. Is it : - Bogner preamp tubes --> line6 effects /sims --> bogner power amp tubes? - Line 6 effects/sims ---> preamp ---> power amp or something else ? Also is there a way to overlap the modeling part and just use the MKII as a tube preamp/amp? I'm guessing that if I just use the "power amp in" , it bypasses the preamp/modeling sections (is this true?) but is there a way to also use the preamp section too?? ...btw, this is pure curiosity, I'm very happy with the amp sounds! Thanx in advance! :) Quote Link to comment Share on other sites More sharing options...
napynap Posted October 24, 2013 Share Posted October 24, 2013 AntonisPat, It's difficult to definitively answer your question, (which I feel is more than just a curiosity for you), but with the following info, maybe it will help you find an answer. Resources: Line6 Spider Valve Advanced Guide: http://line6.com/support/manuals/sv112 Preamp Out: Use the Preamp Out to send your Spider Valve MkII DSP Amp and FX modeling output to an external power amp, guitar amp or FX device. Power Amp In – Plug into your Bogner-designed power amp here. ...for example, driving the all-tube power amp. Sv-pre By Strymon http://line6.com/support/topic/1995-sv-pre-by-strymon/ Line 6 Spider Valve MKII 1x12 Combo Amp Review http://www.premierguitar.com/articles/Line_6_Spider_Valve_MKII_1x12_Combo_Amp_Review Preamp Out grabs the signal after the Line 6 modeling pre but before the Bogner-designed tube pre. Quote Link to comment Share on other sites More sharing options...
AntonisPat Posted October 24, 2013 Author Share Posted October 24, 2013 Hello napynap, thank you for your answer! Actually it is a curiosity question, last week I had a gigg with my band in a small festival and the guitarist from another band came along and we started another discussion on amps and guitars. He was quite interersted in my 112 MKII and asked a few questions on pretty much what I'm asking, but all I knew to answer back is what's mentioned in the manual..I felt a bit bad not knowing so here I am! "The first controls on the back are Power Amp In and Preamp Out. Preamp Out grabs the signal after the Line 6 modeling pre but before the Bogner-designed tube pre." (from : Line 6 Spider Valve MKII 1x12 Combo Amp Review) Does that mean that Preamp out gets the modeling but NOT the preamp tubes??? So if I connect something as effects send-return there it will be Modeling->effect loop->preamp tubes->power amp tubes? Again sorry fi I ask something stupid but Im quite new in trying to understand how amps and effects work, all I know is from a few articles I've read! Quote Link to comment Share on other sites More sharing options...
OmeRoon Posted October 24, 2013 Share Posted October 24, 2013 http://www.youtube.com/watch?v=7XfluCJ3czk - here Reinhold himself explains what he did. ;-) 1 Quote Link to comment Share on other sites More sharing options...
AntonisPat Posted October 25, 2013 Author Share Posted October 25, 2013 Ok so from what I understand its modeling --> preamp --> poweramp. Thanx guys! Quote Link to comment Share on other sites More sharing options...
AntonisPat Posted November 8, 2013 Author Share Posted November 8, 2013 Hello all again Since you are so kind, I have another question :) : I want to play at low volumes at home, but I still want to push the valves as much as possible to get that nice tone they give. To do that, is it better to play at a moderate channel volume and very low master or low channel and moderate master?? To make the question a bit more general, does the channel volume comes from the modeling and the master from the preamp/amp section or does the channel volume affect the preamp as well ? I'm guessing that the power amp part is 100% master volume, right? Thanx again! Quote Link to comment Share on other sites More sharing options...
OmeRoon Posted November 8, 2013 Share Posted November 8, 2013 I think this is what you are looking for:http://koch-amps.com/dt_portfolio/loadbox-ii-power-attenuator-speaker-simulator/ Also check out this thread as it's more or less the same question:http://line6.com/support/topic/2697-is-there-a-way-ie-different-tubes-etc-to-minimize-master-volume-on-mkii-212/ Quote Link to comment Share on other sites More sharing options...
AntonisPat Posted November 8, 2013 Author Share Posted November 8, 2013 Hey OmeRoon, thanx, but thats a 300-400$ extra cost which I'd rather not spend.. I also have the Line 6 UX2 sound card and mostly play through this at home, but I was wondering if I could do something to use the amp too.. The actual question here is which would sound better : high channel volume and low master or low channel and moderate master? Does the channel volume affect the tube section (I'm guessing preamp??) or is it just a master volume matter? What I'm trying to do is take the most out of the tubes at low volumes.. Quote Link to comment Share on other sites More sharing options...
tscoolberth Posted January 20, 2014 Share Posted January 20, 2014 and if you have the Strymon ... tubes-> modeling->pre-amp tubes->power amp tubes. I've been tending on having the Strymon pre-amp maxxed to minimize the on board gain :) Quote Link to comment Share on other sites More sharing options...
