benbutterworth Posted July 4, 2018 Share Posted July 4, 2018 How do I set up the HX effects signal chain/fx block/mixer for 7cm? I'm struggling! What are the mixer and effects loops settings in the HX effects? Stereo? Dual mono? I'm using two amps, and want to set up so drives go into the front of the amp, and delays/reverbs in the fx loops. Main problems: - I don't know how the signal chain should be configured to set up 7 cable method into the fx loops of two amps. - Because the setup isn't correct, I currently get a lot of noise as both amps are sending the preamp to the other amp! Basically both preamps are blended on each amp. - How do I ensure delays and other effects are stereo - as in ping-pong delay etc. What are the mixer and effects loops settings in the HX effects? Stereo? Dual mono? Quote Link to comment Share on other sites More sharing options...
Teemi Posted August 18, 2018 Share Posted August 18, 2018 Set up the HX Effects just like in 4CM, but use both Sends and Returns (one for each pre-amp), and connect the HX Effect's main outputs to each amps Return. If you want to use the pre-amps in parallel, just insert a stereo FX Loop block. If you want to alternate which pre-amp to use, add two mono S/R blocks, both FX Loop 1 block and FX Loop 2 block. Set one of them on and the other bypassed. Then assign them to same switch. Now you can toggle between the two pre-amps. For a more complex setup where you want to add separate effects in front of each pre-amp, you should split the signal, add two mono S/R blocks to each path. If you make the split A/B, you'll be able to assign a switch to select which pre-amp is in use. If you make the split Y, and assign an expression pedal to control the A level and B level of the paths, and you'll be able to smoothly mix between the pre-amp outputs. (See Configuring Split Block Options p 31 for more ideas.) Adding separate send and return blocks gives you even more flexibility, but they also add complexity. The FX Loop blocks are way easier to understand. Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted August 18, 2018 Share Posted August 18, 2018 This is how I have mine setup. I also have Path 1 setup for FX Loop 1 and Path 2 setup for FX Loop 2. If you want to run your effects in stereo, make your Path 1 output PAN LEFT and your Path 2 output PAN RIGHT. This setup works great for me. Just remember that any effects before the FX Loops will be processed in mono regardless if you choose stereo effects or not. No sense wasting the DSP processing power for non-time based effects. I also assign a stomp button for each effect in both paths. In other words, If I select my Delay, it will enable/disable that effect in both paths simultaneously. This should work the same on both the Helix and the HX Effects. Hope this helps you. 4 Cable Method (4CM) Cable #1 Guitar to Helix/HX Effects Guitar In Cable #2 Helix/HX Effects FX Send Loop 1 to Amp #1 Main Input Cable #3 Amp #1 FX Send Loop to Helix/HX Effects FX Return Loop 1 Cable #4 Helix/HX Effects 1/4" Left (mono) Out to Amp #1 FX Return Loop 7 Cable Method (7CM) Cable #5 Helix/HX Effects FX Send Loop 2 to Amp #2 Main Input Cable #6 Amp #2 FX Send Loop to Helix/HX Effects FX Return Loop 2 Cable #7 Helix/HX Effects 1/4" Right Out to Amp #2 FX Return Loop 2 Quote Link to comment Share on other sites More sharing options...
JJWhittington Posted December 25, 2018 Share Posted December 25, 2018 Could you....Virtual Guitars... post a screenshot of what your hx edit window looks like when using the 7 cable method you explained above? I just need to know how to manage paths and where to put loop 1 and 2 in the chain. thanks. Quote Link to comment Share on other sites More sharing options...
alanabreo Posted July 28, 2019 Share Posted July 28, 2019 On 8/19/2018 at 3:30 AM, VirtualGuitars said: This is how I have mine setup. I also have Path 1 setup for FX Loop 1 and Path 2 setup for FX Loop 2. If you want to run your effects in stereo, make your Path 1 output PAN LEFT and your Path 2 output PAN RIGHT. This setup works great for me. Just remember that any effects before the FX Loops will be processed in mono regardless if you choose stereo effects or not. No sense wasting the DSP processing power for non-time based effects. I also assign a stomp button for each effect in both paths. In other words, If I select my Delay, it will enable/disable that effect in both paths simultaneously. This should work the same on both the Helix and the HX Effects. Hope this helps you. 4 Cable Method (4CM) Cable #1 Guitar to Helix/HX Effects Guitar In Cable #2 Helix/HX Effects FX Send Loop 1 to Amp #1 Main Input Cable #3 Amp #1 FX Send Loop to Helix/HX Effects FX Return Loop 1 Cable #4 Helix/HX Effects 1/4" Left (mono) Out to Amp #1 FX Return Loop 7 Cable Method (7CM) Cable #5 Helix/HX Effects FX Send Loop 2 to Amp #2 Main Input Cable #6 Amp #2 FX Send Loop to Helix/HX Effects FX Return Loop 2 Cable #7 Helix/HX Effects 1/4" Right Out to Amp #2 FX Return Loop Hi I know this is an old thread but anyways you could share your template for the 7cable method. Quote Link to comment Share on other sites More sharing options...
glorioso Posted August 8, 2023 Share Posted August 8, 2023 On 8/18/2018 at 9:17 AM, Teemi said: Set up the HX Effects just like in 4CM, but use both Sends and Returns (one for each pre-amp), and connect the HX Effect's main outputs to each amps Return. If you want to use the pre-amps in parallel, just insert a stereo FX Loop block. If you want to alternate which pre-amp to use, add two mono S/R blocks, both FX Loop 1 block and FX Loop 2 block. Set one of them on and the other bypassed. Then assign them to same switch. Now you can toggle between the two pre-amps. For a more complex setup where you want to add separate effects in front of each pre-amp, you should split the signal, add two mono S/R blocks to each path. If you make the split A/B, you'll be able to assign a switch to select which pre-amp is in use. If you make the split Y, and assign an expression pedal to control the A level and B level of the paths, and you'll be able to smoothly mix between the pre-amp outputs. (See Configuring Split Block Options p 31 for more ideas.) Adding separate send and return blocks gives you even more flexibility, but they also add complexity. The FX Loop blocks are way easier to understand. Why doesn’t this work? I get bleeding between the amps. Quote Link to comment Share on other sites More sharing options...
lperry65 Posted August 29 Share Posted August 29 I setup 7CM with two Roland Blues Cube Artists using both fx loops, it works but the sound was thin compared to how the amps sound normally. The signal path was just a drive block followed by two fx loop blocks, then a stereo delay and stereo reverb. After watching that pedal show where they demonstrate polarity using stereo into two amps I think this is my problem, however I cannot find a way to invert the polarity of one of the fx loops and I don’t run a parallel path. Is anyone running the HxFx in 7CM stereo into two amps, is there a way to invert the polarity of one of the sends ? Thanks, Lee Quote Link to comment Share on other sites More sharing options...
