HD500 internal battery
mickroddy
Hi all,
I have a HD500 which loses all user presets whenever power is switched off.  Is there an internal battery that can be replaced? Ive had her open and couldnt see anything thay looked remotely battery like?
Any help would be much appreciated.
Thanks in advance.
Mick
the first thing we need to ask is...
is this a new issue? I mean, it is quite possible that if you are a new user that you simply aren't doing it correctly.
Next up is the always famous... reinstall the operating system.
Hi, thank you bothl for your input.
Ive had the unit for a few years working correctly.
It does it when used as a stand alone.  ie not connected to a computer.
I did a reset, reinstalled the OS etc and still no better.
Any ideas?
Thanks again
Capacitors are somewhat like batteries. They hold a charge.
Check for any scorch burns or more likely discoloration. If you are lucky it might be that simple but usually
requires equipment for electrical troubleshooting past a close magnification of the components and circuit.
