jmp22684 Posted August 23, 2018 Share Posted August 23, 2018 1 Quote Link to comment Share on other sites More sharing options...
PerS Posted August 23, 2018 Share Posted August 23, 2018 Looks really good, clean and compact... Who made the case and what is the size. On my way to make something simillar./ Inspiring... //Per Quote Link to comment Share on other sites More sharing options...
jmp22684 Posted August 23, 2018 Author Share Posted August 23, 2018 Thanks! Here's the case: https://www.amazon.com/gp/aw/d/B0030V3FCG?psc=1&ref=yo_pop_mb_pd_title Next thing I want to do is put some storage in the top for backup cables, picks, Campos, batteries, etc... Quote Link to comment Share on other sites More sharing options...
jmp22684 Posted August 23, 2018 Author Share Posted August 23, 2018 The rockboard mod 2 worked out to be cheaper than the jacks I was going to drill out in the plexiglass. But.... I plugged everything in and it didn't work! Had to pull it apart and fix sloppy solder work on the pcb and the power was just a mess of losely disconnected quick connects smashed in. Ripped those off and soldered that as well. Quote Link to comment Share on other sites More sharing options...
jmp22684 Posted August 24, 2018 Author Share Posted August 24, 2018 Had an idea for the lid. Quote Link to comment Share on other sites More sharing options...
Roberttheprole Posted August 24, 2018 Share Posted August 24, 2018 Right on! Made my shelf outa dense wood, I bet the plexiglass is much lighter! Quote Link to comment Share on other sites More sharing options...
PerS Posted August 25, 2018 Share Posted August 25, 2018 That’s a great idea ... Had an idea that you could only use a suitable bag such as the one in a suitcase to pack shirts in, but maybe a bit stronger/durable, flat square lying loose on top of the Helix. Didn't think of your method... Your method looks interesting. It also means I have to ask how you “fixed” the Helix in the case? Assuming that the cover with the padding do not reaches the Helix, so what’s keeping the Helix in place, preventing it to movewhen lifting the case? I was thinking to fix the Helix with Velcro attached on two or three places underneath. Velcro put on two or three discs/plates, which means that I do not have to remove the feet and keeping the ventilation around the device. Worked on a MIDI board I had before (hade to strips of aluminum with Velcro on both sides width of the Velcro), but the Helix is heavier so have to do some experimenting on this. Or you might have the solution. Have looked at several types of cases, including tailor made, but they are a little too narrow or too wide for what I want to use it for. Yours looks good, but Amazon do not ship to Sweden... Has found one from Swan Flight Cases and one from Rock Case Flight case. The problem with both is that I would like to add a separate expression pedal later and both are a bit too narrow or the next size will be huge. Keep on looking… Will check out the RockBoard mod-moules. Also interesting. The thing is that I have split my gear into two pieces, Helix and a future expression pedal (will go into a case) and one with some irreplaceable pedals… , wireless rx, power switch for my Variax and some more. All mounted on a PT Novo 18. //Per Quote Link to comment Share on other sites More sharing options...
jmp22684 Posted August 25, 2018 Author Share Posted August 25, 2018 You get 6" of height so there's plenty of room. I used a pretty strong adhesive, but I think I'm still just going to run some bolts through the straps and box for extra security. I just used brackets and little washers for the existing screws on the helix. Here's a pic. I do the same with the boss pedal. What's funny is it's a volume pedal, but being used as expression pedal #3 in the helix to control a volume pedal at the end of the effects chain so I don't need to run my signal through any extra cable. With the shure glxd, volume pedal and helix I needed a bare minimum of 32". This case worked out beautifully. Quote Link to comment Share on other sites More sharing options...
jmp22684 Posted August 25, 2018 Author Share Posted August 25, 2018 I finished cleaning it up yesterday before the gig and added one of those magnetic kitchen cupboard latches the keep the plexiglass lid closed. Quote Link to comment Share on other sites More sharing options...
jmp22684 Posted August 25, 2018 Author Share Posted August 25, 2018 Quote Link to comment Share on other sites More sharing options...
jmp22684 Posted August 25, 2018 Author Share Posted August 25, 2018 Seismic audio ships internationally https://www.seismicaudiospeakers.com/pages/shipping-policy And here's the case: https://www.seismicaudiospeakers.com/collections/pedal-board-cases/products/34-inch-pedal-board-case Quote Link to comment Share on other sites More sharing options...
jmp22684 Posted August 25, 2018 Author Share Posted August 25, 2018 Oh and I did put little round 3/8" spacers under the helix at each of the brackets to give it some room to breath underneath. Quote Link to comment Share on other sites More sharing options...
DarrenSMusic Posted December 5, 2018 Share Posted December 5, 2018 I'm late to the party but what did you use for the mic stand fitting? Quote Link to comment Share on other sites More sharing options...
jcarruyo Posted December 16, 2018 Share Posted December 16, 2018 interested in the mic stand fitting as well. Quote Link to comment Share on other sites More sharing options...
