two fx states per snapshot...
rudomat
4 minutes ago, rudomat said:
when i´m on one snapshot, i want to change between two delay settings A and B within this snapshot...just toggle between A and B with one footswitch....
 You can do that. You can assign whatever parameters you want to change to be controlled by a footswitch, and the footswitch will toggle between your chosen min and max values for each parameter. The nice thing is that you can still recall specific value for all those parameters on a per snapshot basis as well.
I guess the one thing I should clarify is that the min and max values for each parameter are per preset, no per snapshot. But you can still have a unique value for each parameter that's assigned to a controlled recalled on a per snapshot basis.
ah ok...that´s what i thought...that means you can have each snapshot have a different parameter on snapshot recall plus within this snapshot have a footswitch recall another parameter and fthen toggle between these two parameters...those two are the same then for all snapshots, right...?
personally, i´m using snapshot one for clean and snapshot two for dirty...those two need different delay or reverb settings...cool were, if i could within this breset toggle between a lighter delay and a louder delay....so have #1A, #1B, #2A and #2B...;-)
That's almost exactly how I set my HX Effects
  • I have an external footswitch (on/off toggle wired with a 10k resistor).
  • The external footswitch is used to control my wet values.... I use it to increase the blend of delay and often increase the number of repeats a little.
  • Important to understand, these "footswitch" values are per preset not per snapshot... but I don't find that to be a limitation.
  • The value of the delay time I leave up to the snapshot and/or have it set to tap.
NOTE: You could do this with an expression pedal as well, but I like the simplicity of an on/off button.
