POD HD Pro X--more than 2 Expression Pedals?
NoCoolUserName
With the right MIDI programming, anything is possible. And those capable of programming such things don't need to ask if it is possible, they ask for the various MIDI codes so that they can make it happen.
So, I will assume you want the simple answer...
The unit only offers 2 expression pedals. You can program each pedal to do multiple tasks, including inverted actions. But you are limited to 2 exp pedals.
You can only have 2 expression pedals, but you can assign those pedals to any effect block to do multiple things.
So, if you're sending MIDI from your controller, you have to assign the MIDI to EXP-1 or EXP-2. From inside the ProX, you can assign those controls to anything you want. So, in essence yours is a Yes/No answer to your question. You'll have to dig deeper into the manual and create various patches that do what you want it to do.
