brokenbones Posted September 12, 2018 Share Posted September 12, 2018 I just got an auxiliary pedal for the EXP2 slot. What i'm trying to do is to leave the Wah effect set to EXP2, but in either heel up/down, i want to be able to bypass the effect. Can the min/max parameters be set to bypass the effect? I was hoping to get away from setting the wah to the factory EXP2 pedal and engaging it with the toe switch. Some songs I play require a quick wah on and off. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted September 13, 2018 Share Posted September 13, 2018 I am not really sure what the question is, but I will say this.... You can turn effects on and off with a numbered foot switch. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted September 13, 2018 Share Posted September 13, 2018 16 hours ago, brokenbones said: I just got an auxiliary pedal for the EXP2 slot. What i'm trying to do is to leave the Wah effect set to EXP2, but in either heel up/down, i want to be able to bypass the effect. Can the min/max parameters be set to bypass the effect? I was hoping to get away from setting the wah to the factory EXP2 pedal and engaging it with the toe switch. Some songs I play require a quick wah on and off. Helix has the auto-engage wah feature you're looking for, but the POD does not. Quote Link to comment Share on other sites More sharing options...
