hardins1 Posted November 2, 2013 Share Posted November 2, 2013 If I make a splitter for my VDI cable and run one to my HD500 and the other one to my HDpro x. can I make a patch on the Hd500 with lets say a strat guitar and a patch on the HDpro x with lets say a les paul guitar and play them both at the same time? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted November 2, 2013 Share Posted November 2, 2013 I would just run the VDI to one and the 1/4 inch to the other. 1 Quote Link to comment Share on other sites More sharing options...
hardins1 Posted November 2, 2013 Author Share Posted November 2, 2013 That would work too. But will I be able to play two different JTV69 guitars at the same time one saved on the HD500 and the other saved on the HDpro x? Quote Link to comment Share on other sites More sharing options...
arislaf Posted November 2, 2013 Share Posted November 2, 2013 No! It doesn't matter how you will connect, you can run 1 guitar at a time, or in 1 unit 2 gutars ( a modeled and the magnets) Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted November 2, 2013 Share Posted November 2, 2013 The JTV can only play one model at a time. I am not sure what would happen if you tried to do a "Y" VDI connection but I wouldn't try it. You can output the Mags separately from the models and have them go through the two pod channels. Be aware that you can't have alternate tunings on the mags so you can't use alternate tunings with mags and models. Quote Link to comment Share on other sites More sharing options...
ext1jdh Posted November 16, 2013 Share Posted November 16, 2013 The VDI is a digital connection. The variax processing occurs within the variax guitar, not in the outboard processor. If you split your cable, you'll just end up with a useless y cable. Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 16, 2013 Share Posted November 16, 2013 The JTV is pretty magical, but not this magical... :) Quote Link to comment Share on other sites More sharing options...
