bsd512 Posted October 29, 2018 Share Posted October 29, 2018 Since getting a Stomp, I've been minimizing block count on some of my presets. To that end, I have several now that use the amp+cab block vs a separate amp and cab block each. Hindsight is 20/20 - but is there any way to turn off just the cab portion of the amp+cab block? The reason I want to do this is to run the raw amp direct into a power amp and on into a real cabinet, bypassing Helix cabinet modeling in that situation. For example, for use with a Line 6 PowerCab and taking advantage of its speaker emulation. Or to do that, am I stuck burning a separate block for the cabinet so I can bypass it independently of the amp? Quote Link to comment Share on other sites More sharing options...
erniedenov Posted October 29, 2018 Share Posted October 29, 2018 I don't think there's any way to remove the cab from an amp+cab block. I'd just delete it and replace it with an amp block. You'd want to change the parameters for whatever real cab you plan to use anyway. 1 Quote Link to comment Share on other sites More sharing options...
spikey Posted October 29, 2018 Share Posted October 29, 2018 Just use the "amp" only (and no cabinet), and you have what you want. 1 Quote Link to comment Share on other sites More sharing options...
bsd512 Posted October 29, 2018 Author Share Posted October 29, 2018 Thanks guys. I do know that ... sometimes I'll want to use the power cab in flat mode where a cab will be needed, and other times in cab emulation mode where a cab is not needed. And I was trying to do it without having to have a separate cabinet block that I could bypass for one case, and enable for the other, but otherwise use the same preset. Thanks for confirming, though. I was hoping maybe there was an option with the amp+cab block that I had missed. Of course, this is no big deal on the Helix where we have plenty of blocks, but on the Stomp it's a bigger issue when you only have 6. It won't be a problem most of the time, but I do have some presets that use all 6 blocks even with an amp+cab block. Thanks! Quote Link to comment Share on other sites More sharing options...
salty09 Posted October 29, 2018 Share Posted October 29, 2018 I would probably just copy the preset with the amp+cab block into a new preset naming it PC-Name or something and replace the amp+cab block with just an amp block. 2 Quote Link to comment Share on other sites More sharing options...
