davidvignola Posted November 6, 2018 Share Posted November 6, 2018 Hi Group. I am a new Helix Floor owner and love it! I purchased it from Sweetwater and it came with a trial of Helix Native. I downloaded and installed it and it worked the first time I used it in Studio One version 4. The next day I went to use Helix Native and as soon as I try to add it to a track in Studio One it simply freezes the DAW. I shut everything down and tried it again but no difference. I am running a MAc Pro with Serria operating system version 10.12.6. I tried uninstalling it and reinstalling it but nothing. I wonder if the trial version is the issue and I am considering simply buying it for $99 but I am afraid that the same issue will result and then it's $99 out the window. :) Anyone else have a similar issue? Thanks in advance Quote Link to comment Share on other sites More sharing options...
soundog Posted November 6, 2018 Share Posted November 6, 2018 It sounds like a lot of people are having a similar problem, using various DAWs. It seems to be some kind of problem with the authorization (I'm guessing). Open up a ticket with Line 6 .....they need to be aware of the issue, and they don't monitor this forum. IF you're able to get a fresh project, fresh track, and fresh instance of Native to open in Studio One, try clicking My Account in the plug-ins lower left corner and logging into your Line 6 account to see if that all goes smoothly. Quote Link to comment Share on other sites More sharing options...
line-6-user Posted November 6, 2018 Share Posted November 6, 2018 Hello Davidvignola. First of all, welcome to the forum! Computers... you would expect the exact process every time you switch it on, but they do have a mind of their own. You say that the previous day it worked fine, so what changed during the time you used it? My first thought is that It seems to be related to Drivers Compatability or that the same driver is being used by another precess. Try updating all of your drivers, including graphic card drivers That might solve your problem. Just yesterday i had a problem with using Reaper and iTunes at the same time, Reaper worked just fine but there was no sound from iTunes, the Play button changed to the Pause button, as it should but the player froze the timer and no sound played, that was odd because it has always worked in the past, so what did change? Well, I disregarded an earlier iTunes update notification. Assuming that might had been the reason, I allowed the update to complete and restarted the PC, from then on everything worked just fine. I doubt if the paid version of Helix Native by itself will solve your problem. Quote Link to comment Share on other sites More sharing options...
benvigil Posted November 11, 2018 Share Posted November 11, 2018 Okay, so same problem, but I have a fix. L6 support was pretty useless as far as solutions on this one. I posted this in another thread of people have the IDENTICAL problem on Windows with Cubase. Reposting it here... I have the EXACT same problem running Presonus Studio One with Hellx Native on macOS! It will run perfectly across multiple launches for about a day (i.e. 24 hours), then it crashes the DAW. However, I DID run it up the flagpole with L6 support and their only suggestion was to completely reinstall the DAW... which made no sense, because all plugin versions (AU, VST) crashed every DAW and VST host I tried it with. But I happened upon a solution: after installation when you use the VST for the first time, it creates a set of folders in your user directory. There is a preferences file that you need to edit. On macOS, it's located here: ~/Library/Application Support/Line 6/Helix Native/Helix Native.prefs In that file, there is a key called "Session Token" -- if you close the DAW, open that file, remove that key and value, and save the file... everything works again... for 24 hours. You'll have to authenticate and log in to Line6 every day. 2 Quote Link to comment Share on other sites More sharing options...
zapenn01 Posted November 19, 2018 Share Posted November 19, 2018 This worked. It's obnoxious as a workaround, but I'm glad you were able to figure that out. Sometimes protecting piracy ruins the experience for actual paying customers. Quote Link to comment Share on other sites More sharing options...
benvigil Posted November 19, 2018 Share Posted November 19, 2018 Well... as far as "protecting piracy" a get it, and don't begrudge Line6 on this. It's the buggy implementation. ;) I created a macOS Automator App (attached) that removes the Session Key for you when you try to run it tomorrow and get the Spinning Beach Ball of Death again. Native De-Beach.zip 1 Quote Link to comment Share on other sites More sharing options...
aen1ma Posted May 22, 2019 Share Posted May 22, 2019 Thanks for the workaround. Had the same problem on Windows10 + Studio One. I hope line6 will fix this soon ... Quote Link to comment Share on other sites More sharing options...
anthonylance Posted July 9, 2019 Share Posted July 9, 2019 yep this works....many thanks Quote Link to comment Share on other sites More sharing options...
zz050 Posted November 6, 2019 Share Posted November 6, 2019 On 11/11/2018 at 2:55 PM, benvigil said: But I happened upon a solution: after installation when you use the VST for the first time, it creates a set of folders in your user directory. There is a preferences file that you need to edit. On macOS, it's located here: ~/Library/Application Support/Line 6/Helix Native/Helix Native.prefs In that file, there is a key called "Session Token" -- if you close the DAW, open that file, remove that key and value, and save the file... everything works again... for 24 hours. You'll have to authenticate and log in to Line6 every day. You sir are a gentleman and a scholar. Sad to say that a year later this is still an issue for people doing a trial of Native, but here we are and I was going crazy with the beach balls just trying to use it in nothing more complex than GarageBand. After reboots or just seemingly random (maybe it would recognize the session token had actually expired or something) it would occasionally work, but then just as you said about 24 hours later it would be dead again and causing an endless beachball anytime I tried to load Native. However, a one-line delete with your instructions and I was back in business - and can resume trying to see if this is worth my $400. Thanks! Quote Link to comment Share on other sites More sharing options...
pyreal2 Posted October 27, 2020 Share Posted October 27, 2020 For Windows users, you will find the "Helix Native.prefs" file in: C:\Users\<Your Username>\AppData\Roaming\Line 6\Helix Native In file explorer you may need to check View->show hidden items to see the "AppData" folder. Quote Link to comment Share on other sites More sharing options...
