MIKEY9966 Posted November 9, 2013 Share Posted November 9, 2013 HI i have been using pod for one year , have used the tuner many times , it will not cut out when turned on, it used to drop the audio when tuning , and i used it for a kill switch to.. now the sound is leaking into my 2 amps and interface when tuning , i have looked for this topic and cant find anything , and need to fix this before my next jig , thanks 1 Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted November 10, 2013 Share Posted November 10, 2013 when the tuner is engaged there is an option on the screen to bypass/mute, turn the knob that controls this option. Quote Link to comment Share on other sites More sharing options...
MIKEY9966 Posted November 11, 2013 Author Share Posted November 11, 2013 when the tuner is engaged there is an option on the screen to bypass/mute, turn the knob that controls this option. And were wouldnthis option be located thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 11, 2013 Share Posted November 11, 2013 It is visible on the display when the tuner is engaged. Turn the little black knob associated with the Mode parameter (I think it's called Mode - but it should be obvious when you look for it). Quote Link to comment Share on other sites More sharing options...
bignath Posted November 11, 2013 Share Posted November 11, 2013 Knob 2 I think. Quote Link to comment Share on other sites More sharing options...
ext1jdh Posted November 11, 2013 Share Posted November 11, 2013 I've never noticed this. Is it a "global" setting? If I turn off the output during tuning, does that stick across all patches and setlists? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted November 11, 2013 Share Posted November 11, 2013 yes. I've never noticed this. Is it a "global" setting? If I turn off the output during tuning, does that stick across all patches and setlists? Quote Link to comment Share on other sites More sharing options...
ext1jdh Posted November 11, 2013 Share Posted November 11, 2013 fantastic. I need to do this. Like, now Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted November 11, 2013 Share Posted November 11, 2013 i like mine on.... but only because i use it in a studio setting primarily, and it's a quick bypass to throw on the tuner if i'm running a keyboard or something else into the input. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 11, 2013 Share Posted November 11, 2013 Essentially the tuner on Mute is a global device mute feature that can be activated and left on for as long as you like. The device CPU will be confused as h#ll trying to calibrate the incoming frequency for the duration, but it will recover nicely as soon as the tuner is disengaged. Quote Link to comment Share on other sites More sharing options...
bignath Posted November 12, 2013 Share Posted November 12, 2013 also useful for when swapping guitars in a live setting between songs. Quote Link to comment Share on other sites More sharing options...
