Sonic-Imagery Posted December 12, 2018 Share Posted December 12, 2018 Is there a way of assigning the Note-Sync portion of the Delay Time to a particular Snapshot? When I do it effects all the other Snapshots, which is not what I want. I do have the Snapshot Edits Preference set to Recall under Global Settings which is working well with all other Snapshot Controller Assignments with the exception of Note-Sync. Is there something I'm missing? Thanks for any information and help regarding this matter... :) Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted December 12, 2018 Share Posted December 12, 2018 Like changing the note value of the delay, or changing the tempo of a Note-Value delay? Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 12, 2018 Share Posted December 12, 2018 You can change the note value on a snapshot per snapshot basis, but you can't change from a note value to a millisecond value. 1 Quote Link to comment Share on other sites More sharing options...
codamedia Posted December 12, 2018 Share Posted December 12, 2018 7 hours ago, phil_m said: You can change the note value on a snapshot per snapshot basis, but you can't change from a note value to a millisecond value. I really wish this wasn't the case... I could seriously cut down on the number of delay blocks I need if I could just bounce between "note value" and "ms value" in snapshots. But - it is what it is, there must be a reason they can't implement it... I can work around it easy enough thanks to the number of blocks I have in the LT. Quote Link to comment Share on other sites More sharing options...
