Gallegos Posted December 20, 2018 Share Posted December 20, 2018 Hi, I would like to pilot my M13 scenes from my HX effects. In particular, I wish to toggle on/off multiple effects units with a sinlge HX footswitch. For example: toggle on/off M13 FX unit 1A and FX unit 2B simultaneously by pressing 1 hx footswitch. It seems that this is not possible right now, as only 1 MIDI CC message can be assigned per footswitch, is this correct? Thanking you in advance. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 20, 2018 Share Posted December 20, 2018 See page 35 of the manual, "Command Center". You can send up to 6 MIDI "Instant Commands" on preset load. Quote Link to comment Share on other sites More sharing options...
Gallegos Posted December 20, 2018 Author Share Posted December 20, 2018 Thanks! I knew that, but it only happens once per preset load. This is good to load a M13 scene ( 12 effects preset loaded with 4 "on" maximum at once), but not enough to change effects combinations within the scene. I think it could be a huge firmware update project to add a way to assign multiple MIDI Messages to the 6 available footswitches. This could be done by adding a setting that allows for a message numbering option: message number ( 1 of N=10? ) followed by the other midi settings ( Midi message type, midi channel, CC# etc.... ). This way, stepping on a footswitch would simultaneously send multiple MIDI messages to various devices while keeping intact the curently loaded HX preset. Quote Link to comment Share on other sites More sharing options...
phil_m Posted December 20, 2018 Share Posted December 20, 2018 This may be a dumb question, but why do you even need the M13? Everything it can do, the HX Effects can do (even better, arguably). Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 20, 2018 Share Posted December 20, 2018 You can use snapshots. I'm assuming, based on a quick look at the HX FX manual, that snapshots on the HX FX work the same as on the Floor. Quote Link to comment Share on other sites More sharing options...
