HX Effects fx loop question
jumpback
Just a simple need for my HX Effects unit, all I need it for is the lush Reverbs and delays/Mod, and my question is; can I run it to my amps fx loop with 2 cables like a regular pedal without creating a send/return block, so It goes after preamp?
I don't need anything in front of the amp..Thanks
If you want to use your amp's preamp, you'll need to use 4cm (page 9 of the manual) -
Guitar>HX Input>S/R Block>HX Send>Amp Input>Amp FX Loop Out>HX Return>Delays/Reverbs etc>HX Out>Amp FX Loop Return.
53 minutes ago, jumpback said:
Thanks folks, hey do you know why my fx loop block is lower in volume when active and really loud when it's not?
Thanks
What is your setup? Are you using the 4CM? If so, you'd actually never want to turn the FX Loop block off in the HX Effects, because doing so would cause your amp's preamp to be bypassed. Which is maybe what's happening here.
Btw, the one post above saying you have to use the 4CM to use your amp's preamp is incorrect. You can put the HX Effects in your amp's effects loop and use it for time-based effects only, like you mentioned in your original post. That will work fine.
Oops! Lost track of whether he was using Helix or HX Effects. My bad!
Thanks again folks, I really like this forum, quick replies!!
So the loudness comes from the bypass oh I get it now, I'm starting to like this pedal now, Oh how can I delete an effect from the pedal and replace it with a totally different one?
