dimatohi 0 Posted January 9, 2019 This is a very good amp, but I would like to know if option SOLO will come with the new software versions. Quote Share this post Link to post Share on other sites
Kilrahi 488 Posted January 9, 2019 On 1/9/2019 at 2:09 PM, dimatohi said: This is a very good amp, but I would like to know if option SOLO will come with the new software versions. Do you mean as one of the presets? None of us here would know since we're just users of the device, but why not just create your own or download one from the cloud? Quote Share this post Link to post Share on other sites
ADBrown 70 Posted January 11, 2019 On 1/9/2019 at 3:09 PM, dimatohi said: This is a very good amp, but I would like to know if option SOLO will come with the new software versions. I'm not sure if your question is in reference to presets or amps models. There are good deal of solo/lead presets in Spider, look for the word "lead" or "solo" in a preset. There is also the "1993 Solo 100 Head" under the High Gain amp category. Quote Share this post Link to post Share on other sites
dimatohi 0 Posted January 14, 2019 NO, I mean that for example on a Boss GT8 pedalboard there is the option to press the SOLO button on a preset and this in turn has a higher volume to make a solo and then turn it off to return to its normal volume, the spider V I understand that I have to make two presets equal but one higher than the other to make a SOLO. Quote Share this post Link to post Share on other sites
Kilrahi 488 Posted January 14, 2019 57 minutes ago, dimatohi said: NO, I mean that for example on a Boss GT8 pedalboard there is the option to press the SOLO button on a preset and this in turn has a higher volume to make a solo and then turn it off to return to its normal volume, the spider V I understand that I have to make two presets equal but one higher than the other to make a SOLO. No, you can do that with the Spider V. There are MANY ways that you could accomplish this. One of the most obvious would be to add a boost pedal to the chain and activate it when you are doing your solo. Quote Share this post Link to post Share on other sites
ADBrown 70 Posted January 14, 2019 1 hour ago, dimatohi said: NO, I mean that for example on a Boss GT8 pedalboard there is the option to press the SOLO button on a preset and this in turn has a higher volume to make a solo and then turn it off to return to its normal volume, the spider V I understand that I have to make two presets equal but one higher than the other to make a SOLO. As Kilrahi pointed out there are a few ways to engage a lead tone. Are you using an FBV3 or any floorboard controller with Spider V? Engaging an overdrive/distortion/boost effect is a good start. Switching between presets is another option. Some banks have presets labeled Clean, Rhythm, Lead, etc. Quote Share this post Link to post Share on other sites
Rayk86ss 3 Posted January 15, 2019 Of course there was always the old flip the switch on the Les Paul trick... Speaking of which it would be nice to have the amp automatically change presets when the switch on the guitar is flipped. I can think of a few ways to accomplish this, but a plug and play solution would be nice. Quote Share this post Link to post Share on other sites
K1dr0b 1 Posted November 6, 2019 If you have the foot controller, you can use it to turn up the volume during lead by using it as a volume pedal. Just set your rhythm volume at half depress and full volume at full depress. Of course, you won't be able to engage the Wah if you use it as a volume pedal. Quote Share this post Link to post Share on other sites
guitardad123 22 Posted November 8, 2019 Just use a boost from a PEQ block. Add about 2-3 db boost in midrange, and another 2 db of the block's level amount. You would need the FBV pedal to engage. I use the SV240, FBV3, and G10T. Quote Share this post Link to post Share on other sites
