aaronlyon Posted January 16, 2019 Share Posted January 16, 2019 I have one input set to Variax Magnetics, and one set to Variax. I want to merge the two paths after the Delay and before the Reverb and Looper. If I choose the output of the first path, the only choice I see is to route it to the 2A input. I can't find any of the split/merge commands. What am I missing? Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 16, 2019 Share Posted January 16, 2019 You can't merge Paths 1 and 2 (at least not directly). You can only merge Paths 1A and 1B or 2A and 2B. You could actually do this by using only Path 1. You could also keep paths 1A and 1B split and have 1A feed 2A and 1B feed 2B and then merge paths 2A and 2B together if you need more DSP. Quote Link to comment Share on other sites More sharing options...
aaronlyon Posted January 16, 2019 Author Share Posted January 16, 2019 That's great, I'd like to try that. When you start with a blank preset, how to you get Path 1 to split into 1A and 1B? Quote Link to comment Share on other sites More sharing options...
aaronlyon Posted January 16, 2019 Author Share Posted January 16, 2019 Finally, found it in the manual! "To create a split path, simply drag a block down." Ah! Thanks. Quote Link to comment Share on other sites More sharing options...
