klasi
No Low Volume Mode
Just bought a used DT25.  When I switch it to LVM the volume remains the same.  The volume definitely does not go any lower.   In fact, when in LVM if I turn up the master volume the sound breaks up (distorts) even more than if in the regular volume mode.  Any ideas on this?
I already did a factory reset.  Problem remains.
Needs to go to a Line 6 authorized service center for a check out.
May need fresh tubes and a proper biasing. And a check-out to be certain that
any old tubes didn't have an adverse affect on anything else.
Does it matter what position the "Standby" switch is in when you toggle between "Low Volume Mode(s)"?
In other words, should the amp be in "Standby" before I switch the "Low Volume Mode" one way or the other?
Not being funny here but the low volume mode works best at lower volumes. It is still quite loud at the higher volume levels.
Try comparing volume 2 with and without the low volume mode switch engaged.
If you turn the amp up from there the low volume mode does get louder but significantly less than normal mode.
