Is MIDI necessary if you're connected via Line6 Link?
klasi
If I'm running my HD500(x) into my DT25 via the L6 Link am I getting the same functionality I would be getting if I were connected via MIDI?   When I switch between patches on the HD500 is it changing all the topology features in the DT25 that would happen if I were instead using a MIDI connection?
Edited by klasi
mispelling
  • 3 weeks later...
I have verified this with many patches, the topology, class, etc.  All change to whatever you have set in the preset.    Its like it's doing a behind the scenes send to your DT with a return, so you can put your effects after the amp, and then the final output goes back to the DT.    So you are using the preamp or amp on your POD, but the output stage on your DT and the effects show up however you specify in your chain on the POD.
