Shootdown Of Variax Modelling
Hello, I have a problem with jTV-69. Often spontaneously disconnected modeling, when I play in amp. Also shootdown of modeling happens and modulation indicator lights red. And still happens when you connect variax  to line6 podhd500, pod freezes and reboots. What can I do? Firmware update does not help
Does the Line 6 monkey see your Variax when you use the USB interface that came with it?  If not, when that happened to me with the older Variax's, it was because I had bent the contacts in the VDI socket when I accidentally tried to plug a 1/4" cable in there.  You will then need to replace that which you can.  Call support and they can tell you the part number and where to go to get it.  I don't have that info with me right now.
