bullvine Posted December 14, 2013 Share Posted December 14, 2013 Hi all, quick question: I'd like to be able to activate my Wah via a footswitch instead of useing the expresion pedal toe switch. I like playing live with my volume pedal around 80% it gives me some room to boost when needed and such. My problem is that in order to switch over to WAH useing the expresion pedal toe switch, I have to max out my volume pedal in order to activate it, then i'm stuck at 100% volume for my Wah when what I really want is about 80%. Is there any way around this? I've tried setting the Wah to be controlled by a footswitch but it doesn't seem to work the way that I was hopeing for. Thanks for your time. Quote Link to comment Share on other sites More sharing options...
ftuller Posted December 14, 2013 Share Posted December 14, 2013 Try freeing up the pedal for the wah by using an effect slot in your chain for a clean boost triggered by footswitch. If you need wah and boost at the same time you can assign both to the same footswitch. The POD HD500 doesn't have a clean boost effect but there are a few ways to do it: short cable into fx loop (add fx loop to chain with +3db return for exanple), or use tube comp with 100% thresh and output to taste (+12-24), or use studio eq with flat settings and output to taste). Here's another post on the ways to do a clean boost: http://line6.com/support/topic/4186-lead-boost-for-hd500x/?fromsearch=1 Quote Link to comment Share on other sites More sharing options...
jandrio Posted December 17, 2013 Share Posted December 17, 2013 Use the "Controller Assign screen" (see POD HD500 Advanced Guide v2.10 - English ( Rev A ), page 3-9) and set the maximum value of the volume pedal to 80%, Quote Link to comment Share on other sites More sharing options...
radatats Posted December 17, 2013 Share Posted December 17, 2013 Probably easiest way is to get a second exp pedal for a dedicated wah. I just got one from Sweetwater for $49... Can't go wrong for that price. :) Quote Link to comment Share on other sites More sharing options...
