HX FX - Delay 4CM
Mandraxx
Ok, I've had my HX a couple of days only so forgive me if I'm missing something simple.  I've routed the cables in the correct way. I start a new patch, add the FX loop as required and I can add effects to the patch.  The problem I have is none of my effects seem to work when putting them after the loop on the signal flow part of the unit.  If I put in a delay for example, it works in front of the loop, but as soon as I move it after, it stops working. Anyone had this or know a simple reason why that would be?
I do have it switched on.
Here are how the cables are connected, just for clarity.
Guitar to HX L/Mono input
Amp Main Input to HX FX Send 1
Amp FX return to HX L/Mono Output
Amp FX Send to HX Return 1
I'm just using standard guitar cables to connect it with, is that correct?  Or should I be using something else?
That's the correct cable connections. What amp are you using? It seems like perhaps the amp's effects loop isn't turned on.
I think the loop might be the issue. It's a Katana.  I tried to run the HX through the loop only and that doesn't seem to work either.  I need to boot up the Katana software and have a look what's happening with the loop I think.  Thanks for getting back to me guys.  I will report back once I've had a look at what's going on with the Kat.  In the meantime I'm running the HX through the front of the amp and it's great, so no complaints.
Edit:  Once again thanks for the help. It appears that somehow my loop had been disabled via the Katana software.  Everything is working fine now.
