schapman1022 Posted July 14, 2019 Share Posted July 14, 2019 I am having an bit of an issue with noise/buzz in my home studio, but it is only when a guitar is plugged in. It also seems to be the worst when the AC or Heat is on in the house. It happens with all my guitars, both passive and active pickups. I bought a new Mogami Gold cable to make sure it wasn't my cables but the issue continues. Here is my current set up: Guitar > Line 6 Helix > Yamaha HS8's (Helix and HS8's are plugged into Livewire PC1100 Power Conditioner) Everything is silent before a guitar is plugged into the input of the Helix or an amplifier. I'm trying to figure out if the following products would help with the issue or not but I'm not sure what exactly this noise is... RFI, EMI, etc? Noise Harvester - https://www.psaudio.com/products/noise-harvester/ Hum Eliminator HE-2 - http://www.ebtechaudio.com/hedes.html Here are the sound clips: AC on, no noise gate on Helix - https://www.dropbox.com/s/xsmme3n7lq...0Gate.mp3?dl=0 AC off, no noise gate on Helix - https://www.dropbox.com/s/gk59dcrim4...0Gate.mp3?dl=0 Each of these is me changing channels from Clean, OD, Rhythm and Lead. Each change happens after about 10 seconds. There is noise in both but with the AC off sounds a little more like a normal hiss of an amp but I could be wrong. Any ideas what is causing this issue or how to fix? Quote Link to comment Share on other sites More sharing options...
schuha_at Posted July 16, 2019 Share Posted July 16, 2019 Hard to diagnose remotely. From the stomach I suspect rather problems with the grounding or installation of the house or interferences of devices like fluorescent lamps, TV monitors etc.. Try another active box. Bypass the Power Conditioner. Try setting up your equipment at another place in your house. If you have a good friend, ask him if you can try your equipment in his apartment. Maybe you can at least narrow down whether it's your equipment or your environmental conditions. Good luck! Quote Link to comment Share on other sites More sharing options...
reginaldStjohn Posted July 16, 2019 Share Posted July 16, 2019 Are you using the USB connection to a computer? If you are this can create another ground path. If you are using a USB connection un-plug it and see if the noise changes. Quote Link to comment Share on other sites More sharing options...
schapman1022 Posted July 17, 2019 Author Share Posted July 17, 2019 16 hours ago, schuha_at said: Hard to diagnose remotely. From the stomach I suspect rather problems with the grounding or installation of the house or interferences of devices like fluorescent lamps, TV monitors etc.. Try another active box. Bypass the Power Conditioner. Try setting up your equipment at another place in your house. If you have a good friend, ask him if you can try your equipment in his apartment. Maybe you can at least narrow down whether it's your equipment or your environmental conditions. Good luck! Got the Hum Eliminator HE-2 in the mail today... didn't help. Moving the equipment to the opposite side of the house seemed to help some. Really seems to just be an issue with the AC, heat or now noticing the washer and dryer are on. The guitars are really picking up some sort of interference in the air. I'm going to be trying at my buddies house this weekend where I have used before... I know it's something here at home though cause it was never an issue at his place. Quote Link to comment Share on other sites More sharing options...
schapman1022 Posted July 17, 2019 Author Share Posted July 17, 2019 5 hours ago, reginaldStjohn said: Are you using the USB connection to a computer? If you are this can create another ground path. If you are using a USB connection un-plug it and see if the noise changes. It's the same with or without the USB connection. Quote Link to comment Share on other sites More sharing options...
schuha_at Posted July 17, 2019 Share Posted July 17, 2019 5 hours ago, schapman1022 said: I know it's something here at home though cause it was never an issue at his place. Now one step has been taken. For the solution you should hire a specialist. It should at least be ensured that personal protection is guaranteed with your installation. One consolation could be that you probably don't have these problems with a GIG. Quote Link to comment Share on other sites More sharing options...
jshimkoski Posted July 17, 2019 Share Posted July 17, 2019 I had the same sort of issue when I was running the Helix alongside a Mission Engineering Gemini 1. It was ridiculously noisy/buzzy no matter what I tried. The solution i came up with was a Furman power conditioner (I think it was this guy: https://www.sweetwater.com/store/detail/PL8C--furman-pl-8c-15a). Maybe give something like that a try? Quote Link to comment Share on other sites More sharing options...
schapman1022 Posted July 17, 2019 Author Share Posted July 17, 2019 3 hours ago, jshimkoski said: I had the same sort of issue when I was running the Helix alongside a Mission Engineering Gemini 1. It was ridiculously noisy/buzzy no matter what I tried. The solution i came up with was a Furman power conditioner (I think it was this guy: https://www.sweetwater.com/store/detail/PL8C--furman-pl-8c-15a). Maybe give something like that a try? I have a Livewire PC1100 but maybe it just isn't cutting it.. Was it a buzz that happened without a guitar plugged in or was it a buzz that changed as you moved and turned your guitar around the room? Quote Link to comment Share on other sites More sharing options...
jshimkoski Posted July 17, 2019 Share Posted July 17, 2019 It was a buzz that happened when I would just turn the Helix and the Gemini 1 on. The power conditioner solved the issue issue for me. Quote Link to comment Share on other sites More sharing options...
schapman1022 Posted July 18, 2019 Author Share Posted July 18, 2019 5 hours ago, jshimkoski said: It was a buzz that happened when I would just turn the Helix and the Gemini 1 on. The power conditioner solved the issue issue for me. Thanks..not sure that will work for me here. Everything is quiet on my end until a guitar is plugged in and then the noise changes as the guitar moves and is pointed in different directions Quote Link to comment Share on other sites More sharing options...
