lcuturic23 Posted July 23, 2019 Share Posted July 23, 2019 Hi everyone! I wanted to record a quick riff in Reaper using my Helix LT, but Helix doesn't show up under ASIO devices. It does show up when opening the Updater and I hear Windows sounds coming thorugh my Helix. What should I do? I have the latest drivers and software; it used to work a few days ago and now it randomly disappeared, only HX Stomp shows up for some reason (which I don't even have). Thanks! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 23, 2019 Share Posted July 23, 2019 Are you plugged into a hub? Try different USB ports. Is HX Edit working? Is it on the same version as the Helix? Try unplugging the USB for a moment (with Reaper and HX Edit closed), then re-plugging. Try shutting it all down, then rebooting starting with Helix (wait till it's fully booted before starting the computer). If that doesn't work, try re-installing the ASIO drivers. All I can think of right now. I have Stomp and Helix Floor on separate laptops, both show both Stomp and Floor drivers. Quote Link to comment Share on other sites More sharing options...
lcuturic23 Posted July 24, 2019 Author Share Posted July 24, 2019 I was plugged in with the Helix switched on, tried all different USB ports, restarted the computer and the Helix multiple times, updated Reaper but nothing helped. Eventually reinstalled the Helix driver but it randomly keeps disappearing the next time. HX Edit and Updater both work, they're all the newest version, as is my Helix. Quote Link to comment Share on other sites More sharing options...
line-6-user Posted July 29, 2019 Share Posted July 29, 2019 I had the same problem with helix floor and the Berhinger XR18 not showing in Reaper after updating to 2.80 re-installed their drivers solved the problem... at least it still appears so. Try uninstalling the the drivers before restarting your computer, then re-install. Quote Link to comment Share on other sites More sharing options...
