Sign in to follow this
tommasoferrarese
HX STOMP knobs
Hi everybody
I lost one of the knobs from my HX stomp, and another one is repeatedly coming off.. do you know where I can find some good replacement knobs? I'm thinking about replacing them all, as they are starting to come offend I don't want to lose another one..
Thanks!
this will be hard to come by OEM. try Support, but I doubt they'll be able to help (unless youre still under warranty?) This shouldn't happen and a replacement might be an easy 'get'. try to contact one of the Stomp development/online guys to take mercy on you in sourcing a part/pointing you in the right direction.
if not under warrnty or you just want a different knob to dress your HXS:
  • measure exact knob dimensions
  • google (image search) aluminum knobs to locate possible sources
also search sites like; digikey, mouser, markertek, DIY pedal/stomp box sites, finally; ebay, amazon
good luck
I am pretty sure the Helix and the HX Stomp use the same encoder knobs. Might want to double check with Line 6 before ordering....
https://www.fullcompass.com/prod/525523-line-6-30-45-0049-edit-knob-for-helix
If you want a 3rd party knob with a set screw... measure the shaft width and buy any knob that will fit. 1/4" shaft is common, but I'm not 100% sure that is correct in this case.
I have seen reports that these knobs are secured with a small dab of adhesive. If they are coming off easily... I would assume the adhesive has let go. If you go to take one off and it is being difficult, be careful. You don't want to damage the encoder itself.
