Moon_Raven
How to change buffer size
Hello,
I am using Line6 Helix as an audio interface for my computer. I am trying to change the buffer size from my DAW(Ableton live), but when I open the ASIO Helix driver, I see no such options. Is it possible to change buffer size from the default 128 samples?
In PREFERENCES - AUDIO click HARDWARE SETUP.
There's a Slider titled ASIO BUFFER and the range is EXTRA SMALL to EXTRA LARGE.
It's stupid, but it is what it is. EXTRA SMALL is 64.
If you're trying to use the Helix in a direct monitoring scenario, you probably won't like the results. Line 6 doesn't make low-latency drivers for the Helix line.
