godfather_77 Posted October 8, 2019 Share Posted October 8, 2019 When listening to various presets (factory presets) I'm getting audible popping sounds in my headphones. I have used three different headphones and two are studio monitor type and I can still hear the pops so I don't think its the headphones. Any ideas at what may be causing this? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 8, 2019 Share Posted October 8, 2019 Are you plugged directly into the Stomp AND not monitoring through a DAW? Quote Link to comment Share on other sites More sharing options...
godfather_77 Posted October 8, 2019 Author Share Posted October 8, 2019 Yes I 'm plugged directly into the stomp and its connected to my laptop so I can use HX Edit. Not using a DAW Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted October 8, 2019 Share Posted October 8, 2019 Disconnecting your HX Stomp from your Laptop so that you would only be using the HX Stomp directly with your instrument. If the interference is no longer present, it would point to the Laptop, it's USB port, USB configuration, or USB cable as possible causes. Try another USB cable, then another USB port on your laptop (if it has multiple, the one closest to the power jack is recommended). Do not use a USB hub. If you can, try swapping out the cable. Try another Laptop if possible. It is also possible it could be the USB port on the HX Stomp. Quote Link to comment Share on other sites More sharing options...
godfather_77 Posted October 8, 2019 Author Share Posted October 8, 2019 I will try your suggestions, thanks. Quote Link to comment Share on other sites More sharing options...
