popping in headphones when using with HX Stomp
godfather_77
When listening to various presets (factory presets) I'm getting audible popping sounds in my headphones. I have used three different headphones and two are studio monitor type and I can still hear the pops so I don't think its the headphones. Any ideas at what may be causing this?
Disconnecting your HX Stomp from your Laptop so that you would only be using the HX Stomp directly with your instrument. If the interference is no longer present, it would point to the Laptop, it's USB port, USB configuration, or USB cable as possible causes. Try another USB cable, then another USB port on your laptop (if it has multiple, the one closest to the power jack is recommended). Do not use a USB hub. If you can, try swapping out the cable. Try another Laptop if possible. It is also possible it could be the USB port on the HX Stomp.
