maninthedesert Posted October 24, 2019 Share Posted October 24, 2019 i found a pod hd 500x floor pedal for 250 at a pawn shop is it wort buying Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 24, 2019 Share Posted October 24, 2019 the alternative is? a new one for $500. a helix for $1500. A kemper for $3k. New, the 500x was/is the best device in its price range. Used would be no different - which means all of the boss and vox type devices are still not going to be better buys. *this assumes there is nothing wrong with the unit Quote Link to comment Share on other sites More sharing options...
hurghanico Posted October 24, 2019 Share Posted October 24, 2019 8 hours ago, maninthedesert said: i found a pod hd 500x floor pedal for 250 at a pawn shop is it wort buying not a bad price for a used HD500X, but you should carefully check that everything is working fine. not so easy if you don't know well the device and what to check: obviously all the knobs and switches should be checked, the audio outputs (headphones included) and FX LOOP connections, USB port (easily broken in used units) and it is very important, the expression pedal etc. some of the above listed things need the activation of some blocks to be properly checked. if you have a friend who knows quite well the device let him check it for you. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
joel_brown Posted October 24, 2019 Share Posted October 24, 2019 I'd consider the Helix Stomp new for $599. It sounds a lot better and is easier to use. 1 Quote Link to comment Share on other sites More sharing options...
mara17 Posted October 24, 2019 Share Posted October 24, 2019 17 hours ago, maninthedesert said: i found a pod hd 500x floor pedal for 250 at a pawn shop is it wort buying If it is 100% working ok it sounds ok deal. Quote Link to comment Share on other sites More sharing options...
maninthedesert Posted October 24, 2019 Author Share Posted October 24, 2019 so far all is good with everthing waiting on the update on the flash Quote Link to comment Share on other sites More sharing options...
