Thuggies Posted October 31, 2019 Share Posted October 31, 2019 Helix Connected to 2 Separate Power Cab Plus 1x12 Can I run a separate cab configurations to each speaker? I can an XLR going out to each. Let me know if you have any ideas or if anyone has done this yet. Thanks all!! Jeff Quote Link to comment Share on other sites More sharing options...
waymda Posted October 31, 2019 Share Posted October 31, 2019 Yes. Use Line 6 Link is the easiest way, and daisy chain the PC+s together. Modify the settings of each PC+ cab independently in HX Edit at the output block (or on the Helix). Quote Link to comment Share on other sites More sharing options...
Thuggies Posted October 31, 2019 Author Share Posted October 31, 2019 Hi Waymda - Thanks for the response! This is sans a PC connection, but I could use Edit to configure. Basically, this is the setup: Helix > PowerCab Plus 1x12 > PowerCab Plus 1x12 Within the same patch, I'm just wondering if I can have separate Amp/Cab combos go to each separate 1x12? Quote Link to comment Share on other sites More sharing options...
lawrence_Arps Posted November 1, 2019 Share Posted November 1, 2019 are you asking about having diffeent speaker settings on each of the two PC+s...then Yes. If you are asking if you can have two outputs (L&R?) from the helix withdifferent Cabs in those chains and the PC+s running in FRFR mode...Yes. You could even run two completely seprate chains from one input with diffrent FX and aAmps and cabs etc on each, going to the two PC+s in FRFR mode... or you could save the bock and run no cabs in the helix as noted above... Quote Link to comment Share on other sites More sharing options...
jc_anderton Posted November 1, 2019 Share Posted November 1, 2019 13 hours ago, Thuggies said: Hi Waymda - Thanks for the response! This is sans a PC connection, but I could use Edit to configure. Basically, this is the setup: Helix > PowerCab Plus 1x12 > PowerCab Plus 1x12 Within the same patch, I'm just wondering if I can have separate Amp/Cab combos go to each separate 1x12? Think when waymda said 'PC' he was referring to Powercab, not Personal Computer Quote Link to comment Share on other sites More sharing options...
Thuggies Posted November 2, 2019 Author Share Posted November 2, 2019 @JC - Yes thank you - I honestly did think that at first clearly. :X Quote Link to comment Share on other sites More sharing options...
tooloudtoobad Posted November 4, 2019 Share Posted November 4, 2019 I have 2 PC Plus cabs I use the line 6 Link cable to the first cab and another link cable between the 2 PC plus cabs...... I use the speaker simulations in the power cab and you can set them to be the same or you can set them to be different speaker types for each preset or each snapshot...... Quote Link to comment Share on other sites More sharing options...
Tboneous Posted June 28, 2021 Share Posted June 28, 2021 I would like a marshall in one power cab and a fender in the other. How do I do that? Quote Link to comment Share on other sites More sharing options...
