JaPPa Posted January 3, 2020 Share Posted January 3, 2020 Hi everyone! I just received my Line 6 Variax Standard today and when I was trying it out with the magnetic pickups I heard a resonating/high chime sound, especially when playing the D chord. I've tried to lower the magnetic pickups but it is still there, so it's not string pull I guess. When enabling the modeling the same can be heard but it's much harder to detect but it is still there. Is this normal is the guitar bad, or the setup? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 3, 2020 Share Posted January 3, 2020 Probably the set-up, fret buzz, string nut slots or pick-up height to the strings,... needs to be checked out by a Line 6 authorized service tech. Did you change string gauges on it? Quote Link to comment Share on other sites More sharing options...
JaPPa Posted January 3, 2020 Author Share Posted January 3, 2020 Lowering the pickups did not make a difference. The guitar was setup by a authorized Line 6 dealer. The action is pretty high tho and some fret buz can be heard sometimes but not when playing the D chord. It can be heard when unplugged, it sounds like it's coming from inside of the guitar. Quote Link to comment Share on other sites More sharing options...
JaPPa Posted January 3, 2020 Author Share Posted January 3, 2020 15 minutes ago, psarkissian said: Did you change string gauges on it? They put 10's from Elixir on the guitar for me (not sure if this is default) string gauges. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 3, 2020 Share Posted January 3, 2020 Yes,... D'Addario Xl-110, 10-gauge set is factory. Sounds like something with the set-up. Line 6 dealer is okay, Line 6 authorized service tech is better. Quote Link to comment Share on other sites More sharing options...
JaPPa Posted January 3, 2020 Author Share Posted January 3, 2020 I included a recording of the sound. It almost sounds like a spring reverb. No effects, straight from the amp (Vox AC4) into iPhone Garageband recording. Hope this can clarify it better if it is a setup-up problem or a defect. Line 6 variax sound.m4a Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 3, 2020 Share Posted January 3, 2020 Sounds like it's mechanical in nature, a secondary vibration, from the string nut or bridge end. Something is fret rubbing somewhere. Should be gone over by a Line 6 authorized service center with the proper service info. Non Line 6 techs won't have the correct set-up info. There can be interactions between piezo and magnetic pick-ups that non Line 6 techs would not know to be aware of. Set-up needs to be done to Line 6 specs. Quote Link to comment Share on other sites More sharing options...
JaPPa Posted January 3, 2020 Author Share Posted January 3, 2020 Where can I find a Line 6 authorized service center in the Netherlands? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 3, 2020 Share Posted January 3, 2020 Hanex Waaier 36 VW Leimuiden, 2451 Phone: +31172506993 Email: info@hanexservice.nl URL: http://www.hanexservice.nl Check with them to be certain they do our guitars. They do our other products. I've dealt with them before in the past regarding our guitar products. Quote Link to comment Share on other sites More sharing options...
