Using Variax to send two signals / paths?
mrmichaelgibson
Hi!
 I am starting to use my Variax more and more (Shuriken) and am trying to see if I can use it to route two signals / paths at one time.  Here is what I would like to do:
 - Path 1 - clean electric sound (using one of the electric models, like the Lester)
 - Path 2 - clean acoustic sound (using one of the Acoustic models)
 I assume I would create a preset with two paths, both coming from the main input.  Is this possible with just the VDI input, or do I need to somehow use the VDI and standard output jack?
Thanks!!!!
You can use two inputs and get two independent signals from the Variax but you can't use two Variax models. One of the inputs can use a model but the other must use the Variax magnetic pickups. This can be done using VDI; no need for the analog output from the Variax.
