p8guitar Posted February 23, 2020 Share Posted February 23, 2020 I have a Fishman Tripleplay attached to my Variax. When I turn down the volume of the Variax guitar with the volume knob of the guitar, the MIDI output of the tripleplay is turned down, too, because MIDI CC 7 (= Volume) is sent. How can I prevent this? When I look in HX Edit command center, there is no midi CC mapped to the volume knob of the Variax! "Command" is set to "none". ?!? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 23, 2020 Share Posted February 23, 2020 If you are not using MIDI for any other purpose you can simply turn off MIDI in the Helix Global Settings. Quote Link to comment Share on other sites More sharing options...
brentmoreland1 Posted February 24, 2020 Share Posted February 24, 2020 Variax Volume is sent from Helix on Channel 16. Set any other midi device to a different channel, or turn Omni off. Quote Link to comment Share on other sites More sharing options...
p8guitar Posted February 26, 2020 Author Share Posted February 26, 2020 Ah! Thank you very much, this solved my problem. How do you know such things? I never saw it mentioned in the Helix or Variax manual. But maybe I didn't read carefully enough. Quote Link to comment Share on other sites More sharing options...
codamedia Posted February 27, 2020 Share Posted February 27, 2020 16 hours ago, p8guitar said: How do you know such things? I never saw it mentioned in the Helix or Variax manual. But maybe I didn't read carefully enough. IMO.... Rule #1 with MIDI is to turn off OMNI and set each device to a discrete midi channel. That gives you control of what you want, when you want, without any surprises. Quote Link to comment Share on other sites More sharing options...
