nuttree Posted February 25, 2020 Share Posted February 25, 2020 I've been using my M13 for a couple months now and generally love it. But I cannot figure out how to get a volume boost for a solo without using an overdrive or distortion effect. Often I want to do a clean solo, perhaps with just some delay or phaser. But those types of effects don't have a gain or output level parameter that I can adjust to boost my signal loud enough for a solo. Am I missing something? Is there some type of "transparent" effect that has an output level parameter I can use for a "clean boost"? Is there some overall setting/preference I should be tweaking? I don't have a volume pedal and I don't want to be dependent on an expression pedal for this. I want to be able to hit one foot switch and not have to do the pedal dance. I run a mono set up, simple input/output with a Fender Hot Rod Deluxe IV. Thanks for the help and suggestions. Quote Link to comment Share on other sites More sharing options...
mylesloud Posted April 14, 2020 Share Posted April 14, 2020 you can use one of the eq's and just boost the eq volume. Quote Link to comment Share on other sites More sharing options...
cdawg22 Posted July 29, 2022 Share Posted July 29, 2022 I suggest trying the Tube Compressor . It is excellent for single coil pickups also. Just don't overly "squash" your signal. Or you could use an EQ. Just set it louder and flat. If you use a Distortion or Overdrive, Set the Pre - Low and set the Post - High. It may still be a little dirty. There's also the Volume model, but I haven't tried using it without an Expression pedal and I am not sure if you can set it louder for a boost. Quote Link to comment Share on other sites More sharing options...
nerkih Posted August 12, 2022 Share Posted August 12, 2022 I use the Tube Compressor patch for that. Sounds excellent on clean channels. There's also a Boost Comp patch in the M13 which models the MXR Micro Amp, which a lot of people used to use as boost pedals back in the day. Quote Link to comment Share on other sites More sharing options...
