chasingMango Posted April 10, 2020 Share Posted April 10, 2020 The following buttons on my PodXT Live stopped working: Save, Edit, Comp, Amp, Gate, EQ, Output Mode / System. All other buttons and knobs work fine. LCD display works fine. As far as I can tell, nothing is loose inside. I did open a ticket, but the L6 rep is unable to help me troubleshoot this deep in the hardware... I figured I'd give it a shot here on the forum. Anyone have any thoughts as to what could make these buttons stop working? I figure they are all connected via a single path, something in the path went bad, just don't know what it is. Quote Link to comment Share on other sites More sharing options...
daveny5 Posted April 10, 2020 Share Posted April 10, 2020 Did you try performing a factory reset? You could also try unplugging and replugging the cables on the motherboard carefully. Try the one labeled To Pedal PCB. 1 Quote Link to comment Share on other sites More sharing options...
chasingMango Posted April 10, 2020 Author Share Posted April 10, 2020 1 hour ago, daveny5 said: Did you try performing a factory reset? I did re-flash the latest firmware, which I believe is the equivalent to a factory reset? 1 hour ago, daveny5 said: You could also try unplugging and replugging the cables on the motherboard carefully. Try the one labeled To Pedal PCB. Hmm... I will probably try this, if I do I'll let you know how it goes. Quote Link to comment Share on other sites More sharing options...
Ruttster Posted May 6, 2020 Share Posted May 6, 2020 The capacitor (C98) just above the "To Pedal PCB" harness, looks like it is bulging. Check the top of the capacitor and make sure it is completely flat. Quote Link to comment Share on other sites More sharing options...
