pbatts
How to Use the Mission SP1-L6H Toe Switch with Line6 Helix and HX
Introduction
Mission Engineering manufactures two expression pedals designed specifically for use with the Helix product line.
The EP1-L6 is an expression only pedal and does not have a toe switch. It has one (TS) jack for Exp output. This pedal is designed to work with Helix Floor, LT, HX Stomp and HX Effects.
The SP1-L6H is an expression pedal that includes a toe switch. This pedal is designed to work with Helix Rack only and has two separate output jacks. One (TS) jack for Exp output and one (TS) jack for the toe switch output. The toe switch is a SPDT (Single Pole Double Throw) momentary contact (commonly referred to as "non-latching") switch. This pedal is designed for exclusive use with Helix Rack. For HX Stomp - If the desire is to simply use the SP1-L6H toe switch as an external foot switch 4 or 5, no modifications to the SP1-L6H are required. It will perform that function right out of the box.
There is no provision in Helix Floor, LT or HX Effects to use an external expression pedal toe switch as an additional controller or foot switch but with a mod we can utilize this functionality.
Both pedals incorporate a 10K ohm pot for the expression output and both are built in the exact same enclosure/housing. The additional holes in the EP1-L6 have plugs installed in them.
Purpose
To modify either the EP1-L6 or the SP1-L6H so as to be able to utilize the toe switch output as an expression input to the Helix Floor, LT, HX Stomp or HX Effects.
Use Case
The idea of utilizing the toe switch came up when a user wanted to use the SP1-L6H as a traditional Wah pedal. Meaning the toe switch would simply toggle the Wah block in their Preset ON or OFF.
With a little imagination there could be many more use cases. For example, the toe switch could toggle on a Delay block and then use the expression to control the Delay's Feedback parameter.
Or the toe switch could be used to set any parameter on any block, completely independent of what the expression output is controlling.
The Modifications
This mod is easily performed on the EP1-L6 pedal also as the housings are the same. The holes are already drilled and have plugs in them.
Notes on modifying the EP1-L6 (non-toe switch pedal) - As mentioned above, both pedals are built in the same enclosure. These modifications will require the addition of a (TS) output jack (along with the additional components listed below) if you are adding this feature to the EP1-L6 pedal. Also, you may need to add a felt or other pad under the treadle to engage the toe switch.
For HX Stomp Only - If the desire is to simply use the SP1-L6H toe switch as an external foot switch 4 or 5, no modifications to the SP1-L6H are required. It will perform that function right out of the box.
Parts Needed
1 -- Replacement Toe Switch as described below. The stock toe switch for a Crybaby Wah is a perfect replacement.
1 -- 100 ohm resistor. 1/4 watt is fine. The 100 ohm value is a suggestion. You can use whatever low value you have on hand. The Exp Input just needs to see something when the switch is off, or Helix will default back to the onboard Exp Pedal. Whatever value you end up with, you will need to adjust the "Bypass Assign" "Position" parameter to match that resistance value for the parameter being controlled to enable. For a 100 ohm resistor this will be about 25%.
1 -- 10K ohm resistor. 1/4 watt is fine.
* The 10K resistor could be a pot or trim pot if a variable output is desired. This could be used for more granular control of the toe switch's expression input to the Helix/HX.
* For the purpose of this article, the above resistor values will be used.
For the SP1-L6H
1. Replace the stock toe switch with a SPDT (Single Pole Double Throw) maintained contact switch. Commonly referred to as "latching". The stock toe switch for a Crybaby Wah is a perfect replacement.
2. Solder one end of the 100 ohm resistor to the N.O. terminal of the new toe switch.
3. Solder one end of the 10K ohm resistor to the N.C. terminal of the new toe switch.
4. Solder the two loose ends of the resistors to the Red wire going to the output jack.
5. Solder the C (common) terminal of the new toe switch to the Black wire going to the output jack.
DONE
Setup
For this example we will use the expression pedal with it's new toe switch functionality as a traditional Wah pedal. Pressing the toe switch once will turn the Wah block ON. Pressing the toe switch again will turn the Wah block OFF.
For Helix, LT and HX Effects
1. Select the Wah Block in your Preset.
2. Select Main Menu
3. Select "Bypass Assign"
4. Set "Switch" to whichever Exp Input you are using for the Toe Switch.
5. Set "Position" to 25%.
6. SAVE SAVE
7. Select Main Menu
8. Select "Controller Assign"
9. Set "Parameter" to "Position".
10. Set "Controller" to the exp input you want to use for the Wah function.
11. SAVE SAVE
DONE
For HX Stomp
1. Select Main Menu
2. Select "Bypass Assign"
3. Set "Switch" to the expression input you want to use for the toe switch input.
4. Set the Position parameter to 25%.
5. SAVE SAVE
6. Select Main Menu
7. Select "Controller Assign"
8. Set "Param" to "Psition".
9. Set "Controller" to the expression input you want to use for the Wah function.
10. SAVE SAVE
DONE
Go play guitar.
I ordered a Dunlop ECB035 and there are no pinout diagrams or markings that I can see.   It is a DPDT switch but in looking at the picture above I wonder if I was supposed to order a SPDT?  Can someone help me with a wiring diagram?  I very much so want to use the toe switch on my SP1-L6H as a bypass on my Helix floor.  Thanks in advance!
The DPDT switch you have is fine. You will only need to use one side. The C common, the NC normally closed and NO normally open terminals will be identified on the switch.
Thanks very much!   I swear to god there are no markings on this thing!   I'm looking at it with a magnifying glass app.   Geesh.   I can't even find a datasheet or something indicating the pinout.
This mod has my curiosity.
I bought the version that works with the floor model when I had to replace my Helix LT due to it's standard expression pedal breaking.
The  SP1-L6H serves just as volume pedal due to lack of toe switch.
One goal would be to set up the external control to control volume with switch disengaged an then wah while engaged.  And set up the built in expression pedal for say a whammy pedal.
Typically the center terminal is C and the two outside terminals are NO and NC. You can check it with an ohmmeter or continuity tester. You are just using one half of the switch.
Yes, this is easily done. You can use Exp 2 and 3 for the Mission pedal and have Exp 1 for whatever you want.
Well now I've done it.  I bought a Helix Rack so now I need to wire the Mission back up as it was from the factory.  Minor problem.  I think I tossed the original toe switch and didn't take a picture of the wiring.   Can someone please remind me what toe switch was in this thing and how to solder it back up (connection points)?
I can't find any before pics but the toe switch is a SPDT (Single Pole Double Throw) momentary contact (commonly referred to as "non-latching") switch wired to the one (TS) jack for the toe switch output.
Is anyone successfully using this with an HX Effects? I'm trying to decide if I should get the SP1, or just get the non-switching version to control the HX Effects wah function.
They are the exact same pedal. One has the switch, the other doesn't. The one with the switch has two jacks, one for exp and one for the switch.
Get the one with the switch. If you find you can use it (now or later) great, if you can't, no loss. Last I looked (not lately) they were the same price.
I'm interested how this works for the LT as it only seems to have one input for expression pedal 2. How do I connect the two outputs on the Mission pedal to the one input on the LT?
There is a $10 difference right now, at least on Sweetwater, but your same logic still applies and that seems a small extra price to pay for the flexibility and future-proofing.
I'm wondering as well how it would connect to the hx effects, if there is toe switch functionality in the future. I'm already using one of the ext jacks to channel switch my amp.
I'm not an HX Effects user, but the same principles still apply.
From the HX Effects manual:
Two expression pedals can be connected to the HX Effects device and assigned to adjust a wide variety of parameters.
The modified exp pedal can be used to control either of those, just as in all of the examples above.
I would not expect to see any specific "toe switch functionality" added to HX Effects or any other unit that does not already have that functionality. Even it it was, the modified toe switch, with the added resistors, would likely not work. BUT, IF that functionality was added, the unmodified pedal would work just as it does with the Helix Rack.
The modified toe switch mimics an expression pedal in a cocked, fixed position. That position being determined/represented by the value of the fixed resistors that are installed with the mod.
I'm not an Helix LT user but here goes.
From the Manual:
EXP PEDAL 2/EXT AMP An additional expression pedal can be connected to Helix LT and assigned to adjust a wide variety of parameters. See "Quick Controller Assign" Alternatively, this jack can be connected to your traditional guitar amp to switch its channels or turn its reverb on and off. Use a TRS cable for dual operation (1=tip, 2=ring). To set this jack's function, see "Global Settings > Preferences"
It only has one jack, but that one jack has a dual function. You could use a TRS to two TS 'Y' adapter and use the Expression input on one and the switch input on the other.
In that scenario, you would not need to modify the Line 6/Mission Exp pedal and can use it right out of the box.
Is it possible to use 2 additional Mission SP1-L6H pedals with Helix Floor, assigning them to turn on the effect and adjust the parameter in this effect, or for example, to adjust the parameters inside the effect?
