PaulTBaker Posted May 31, 2020 Share Posted May 31, 2020 Does the preamp then cab cancel out stereo blocks before them. For example, would the signal be changed to mono by the preamp and cab block. So the stereo minator would just mono after the amp cab... So no need in using stereo until after the amp/cab. Is that correct, or am I missing something. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 31, 2020 Share Posted May 31, 2020 You got it. A mono block after a stereo block collapses the signal to mono. Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted June 1, 2020 Share Posted June 1, 2020 One little clarification -- if you use a Dual Cab block, it is in stereo, with one cab panned hard left and the other hard right. You only get this dual option if your cab block is separate from the Amp block. Otherwise, yes, single cab blocks collapse everything to mono at their output. Quote Link to comment Share on other sites More sharing options...
