jcspirited Posted September 1, 2020 Share Posted September 1, 2020 My Helix jumps banks, I have to press the up or down bank button a certain way and even then it jumps banks. Any info would be helpful Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 1, 2020 Share Posted September 1, 2020 If it happens spontaneously, without you touching anything, it’s either a firmware glitch or faulty hardware. To determine which it is use HX Edit to reinstall the firmware. If it’s still happening open a support ticket for hardware diagnosis and repair. Quote Link to comment Share on other sites More sharing options...
jcspirited Posted September 1, 2020 Author Share Posted September 1, 2020 It seem to be hardware. I’ll reinstall the firmware see if it resolves the issue Thanks silverhead Quote Link to comment Share on other sites More sharing options...
jcspirited Posted September 7, 2020 Author Share Posted September 7, 2020 Did a reset, still bank pumping. Notice the down bank mostly Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 8, 2020 Share Posted September 8, 2020 time to open a support ticket. Quote Link to comment Share on other sites More sharing options...
madmax49 Posted September 8, 2020 Share Posted September 8, 2020 You need to clean the up and down switches or replace them. This has happened to me too and all I did was spray them with contact cleaner. Quote Link to comment Share on other sites More sharing options...
jcspirited Posted September 8, 2020 Author Share Posted September 8, 2020 There is a support ticket open. They told me to do a reset, I did. I responded to it. Mentioned the reset didn’t have any affect. Waiting to hear back. I’ve thought about cleaning the button. I’m concerned about voiding warranty. If I clean it and it’s a bad button. Will it get repaired/replaced? Quote Link to comment Share on other sites More sharing options...
madmax49 Posted September 8, 2020 Share Posted September 8, 2020 If it's under warranty, don't do anything till you hear back from support. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted September 10, 2020 Share Posted September 10, 2020 @jcspirited, I don't think it's a good idea to publicly display your serial numbers… Quote Link to comment Share on other sites More sharing options...
jcspirited Posted September 11, 2020 Author Share Posted September 11, 2020 My bad, just deleted it. Quote Link to comment Share on other sites More sharing options...
jcspirited Posted September 24, 2020 Author Share Posted September 24, 2020 I have heard back from support. They referred me to a local repair shop. Emailed the shop, could take a long time to repair(get parts). Ok, I looked into the extended warranty for the Helix to take advantage of the loaner program. My Helix is still under warranty. Just want the loaner. Because the issue with the bank button happened before I bought the extended warranty. Will I still be able to get a loaner. Or will the pre-existing not qualify. Quote Link to comment Share on other sites More sharing options...
rzumwalt Posted September 24, 2020 Share Posted September 24, 2020 On 9/7/2020 at 6:50 PM, madmax49 said: You need to clean the up and down switches or replace them. This has happened to me too and all I did was spray them with contact cleaner. I have a similar bad footswitch. Did you just spray the posts and let the contact cleaner drain into the switch, or did you open the unit up and spray the switch directly? Thanks. Quote Link to comment Share on other sites More sharing options...
jcspirited Posted September 24, 2020 Author Share Posted September 24, 2020 It is still under warranty. Thought about it, didn’t because of warranty Quote Link to comment Share on other sites More sharing options...
