oktintin Posted September 4, 2020 Share Posted September 4, 2020 Hi I have a simple question about snapshot setting. I proceed exactly according to user manual I would like to have in snapshot 1 distortion and snapshot 2 overdrive. I set it but POD GO still have in both snapshots either distortion or overdrive. Could you please help me? Thanks Michal Quote Link to comment Share on other sites More sharing options...
voxman55 Posted September 4, 2020 Share Posted September 4, 2020 It's much easier using Pod Go Edit. Set up snap 1 and save your patch. Go to Snap 2 and set up as you need, and save patch again. Quote Link to comment Share on other sites More sharing options...
grdGo33 Posted September 4, 2020 Share Posted September 4, 2020 Quote I would like to have in snapshot 1 distortion and snapshot 2 overdrive. And btw you can't switch blocks, so if your block 1 Dst and block 2 is OD that would work, you can turn on/off effects with snapshots. But you can't change a block from distortion to OD or whathever, you can only change parameters (ex; drive = 6 vs 2) or turn effects on/off. Quote Link to comment Share on other sites More sharing options...
cristt Posted September 5, 2020 Share Posted September 5, 2020 I think grdGo33 got it right. If you need distortion and overdrive you need to have both pedals present in your signal chain for your patch. Then in snapshots you simply bypass one and activate the other, and vice-versa. You can't change block type per snapshot, you can only change parameters and set bypass on/off. Quote Link to comment Share on other sites More sharing options...
